StarTech.com 12U 19in Desktop Open Frame 2 Post Rack
Quicklinx: 6B9SWS00 Mfr#: RK12OD
Product Type: Rack, Rack
Hurry, only 3 left in stock!
£40.61 ex VAT
£48.73 inc VAT
Mount smaller rack mountable devices right at your desk with this lightweight 12U 2 post desktop rack. The RK12OD 12U 19in Desktop Open Frame 2 Post Rack provides the perfect mounting option for smaller Audio/Video and IT equipment where space is limited and a full sized cabinet is not required.
The 12U rack features a compact and lightweight free-standing design that is suitable for installation on or around your desk giving you easy access to the mounted equipment in your workspace. This lightweight 2 post rack is engineered to meet EIA rack mount standards and includes a pack of 20 M5 screws and Cage Nuts, allowing you to mount up to five devices into the rack right away.
StarTech.com 12U Open Frame Network Rack - 19" 2 Post Free Standing Desktop Rack for Computer, AV, Media, IT, Data & Server Room Equipment (RK12OD) - rack - 12U
Rack
Rack Type
Open frame
Rack Size
19"
Height (Rack Units)
12U
Product Material
Steel
50.4 cm x 29.2 cm x 58.4 cm
3-year warranty
P/N: CABCAGENUTS6, CABSCREWM5, CABSCREWM52, CABSCREWM6, CABSCREWM62, CABSCREWS, CABSCREWSM6, CABSCRWM520, CABSCRWM620, CABSCRWS1224
Rack
Rack Type
Open frame
Product Material
Steel
Rack Size
19"
Height (Rack Units)
12U
50.4 cm
29.2 cm
58.4 cm
UL, RoHS
Limited warranty: - 3 years
6B9S StarTech.com 1U 19in Steel Vertical Wall Mount Equipment Rack Bracket In Stock £35.78
6B9S StarTech.com 12U 19in Desktop Open Frame 2 Post Rack In Stock £40.61
6B9S StarTech.com 2U 19in Steel Vertical Wall Mount Equipment Rack Bracket In Stock £34.65
6B9S StarTech.com 3U 19in Steel Vertical Wall Mount Equipment Rack Bracket In Stock £39.01
6B9S StarTech.com 4U 19in Steel Vertical Wall Mount Equipment Rack Bracket In Stock £51.13
6B9S StarTech.com Universal VESA LCD Monitor Mounting Bracket for 19in Rack or Cabinet In Stock £44.03
6B9S StarTech.com Adjustable Rackmount DIN Rail Kit with Top Hat/Mini/G Rails In Stock £76.74
6B9S StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets In Stock £11.90
6B9S StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £29.91
6B9S StarTech.com Black Standard Universal Server Rack Cabinet Shelf In Stock £30.44
6B9S StarTech.com 50 Pkg M6 Cage Nuts for Server Rack Cabinet In Stock £14.39
6B9S StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £27.99
6B9S StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £52.23
6B9S StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £55.25
6B9S StarTech.com 1U 7in Depth Universal Fixed Rack Mount Shelf – 33lbs / 15kg In Stock £25.06
6B9S StarTech.com 8 Port 1U Rackmount USB KVM Switch with OSD In Stock £273.74
6B9S StarTech.com 8 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables In Stock £309.46
6B9S StarTech.com 8 Port 1U Rackmount DVI USB KVM Switch In Stock £600.89
6B9S StarTech.com 24 Port 0.5U Cat5e Patch Panel - RJ45 Ethernet Rackmount Cat 5e 110 Patch Panel In Stock £17.22
6B9S StarTech.com 2U 22in Depth Fixed Rack Mount Shelf - 50lbs / 22kg In Stock £55.31
6B9S StarTech.com 2U 22in Vented Rack Mount Shelf – Fixed Server Rack Cabinet Shelf - 50lbs / 22kg In Stock £43.20
6B9S StarTech.com 2U 16in Universal Vented Rack Mount Cantilever Shelf - Fixed Rack Shelf - 50lbs / 22kg In Stock £36.09
6B9S StarTech.com 2U Rack Mount Cantilever Shelf - Heavy Duty Fixed Server Rack Shelf - 125lbs / 56kg In Stock £50.11
6B9S StarTech.com 1U Brush Strip Horizontal Server Rack Cable Management Panel In Stock £38.24
6B9S StarTech.com 24 Port 1U Rackmount Cat 6 110 Patch Panel In Stock £46.00
6B9S StarTech.com 1U Horizontal Finger Duct Rack Cable Management Panel with Cover In Stock £17.31
6B9S StarTech.com 100 Pkg M6 Screws & Cage Nuts In Stock £55.20
6B9S StarTech.com 50 Pkg M6 Screws & Cage Nuts In Stock £29.89
6B9S StarTech.com 50 Pkg M6 Cage Nuts In Stock £19.69
6B9S StarTech.com 100 Pkg M5 Cage Nuts In Stock £9.55
6B9S StarTech.com 50 Pkg M5 Cage Nuts In Stock £5.39
6B9S StarTech.com 100 Pkg M5 Screws & Cage Nuts In Stock £52.24
6B9S StarTech.com 50 Pkg M5 Screws & Cage Nuts In Stock £27.56
6B9S StarTech.com 50 Pkg M5 Mounting Screws In Stock £15.48
6B9S StarTech.com 100 Pkg M5 Mounting Screws In Stock £30.19
6B9S StarTech.com 50 Pkg M6 Mounting Screws In Stock £16.16
6B9S StarTech.com 100 Pkg M6 Cage Nuts In Stock £26.84
6B9S StarTech.com 100 Pkg M6 Cage Nuts In Stock £26.45
6B9S StarTech.com 22U 36" Knock-Down Server Rack Cabinet with Casters In Stock £501.70
6B9S StarTech.com 19in Cable Management Panel In Stock £23.58
6B9S StarTech.com 2-Post Desktop Rack - 8U In Stock £34.28
6B9S StarTech.com 10-32 Server Rack Screws and Nuts - 50 Pack - Black - TAA Co In Stock £28.33
6B9S StarTech.com 4U Open Frame Desktop Rack - 2-Post - Weight Cap. 66 lbs In Stock £26.53
6B9S StarTech.com M6 Mounting Screws 50Pack In Stock £16.74
Product Type: Rack
Product Type: Rack
