Store your servers, network and telecommunications equipment securely in this 22U solid steel rack. The RK2236BKF 22U 36in Knock-Down Server Rack Cabinet with Casters features a vented glass front door and mesh rear door that provide devices stored in the cabinet with energy and cost-efficient passive cooling.
Supporting a total load capacity of 800 kgs (1760 lbs), the server rack is constructed of steel and aluminum to provide a sturdy platform for valuable server/networking equipment. The rack is easy to assemble at the point of installation for rapid deployment and features a flat-packed design that helps minimize shipping costs.
Save money, with a cost effective, compact shipping container
The cabinet comes in a flat packed box to reduce shipping volume, which significantly reduces your costs in shipping. Plus, because the rack is packaged efficiently, you can easily store the cabinet, for deployment at a later date.
- StarTech.com 22U Server Rack Cabinet with secure locking door - 4 Post Adjustable Depth (5.5" to 28.7") - 1768 lb capacity - 19 inch Portable Network Equipment Enclosure on wheels/casters (RK2236BKF) - rack - 22U
- Product Type
- Rack
- Height (Rack Units)
- 22U
- Product Material
- Aluminium, steel
- 60 cm x 90 cm x 111 cm
- Limited lifetime warranty
- Designed For
- P/N: CABCAGENUTS6, CABSCREWM5, CABSCREWM52, CABSCREWM6, CABSCREWM62, CABSCREWS, CABSCREWSM6, CABSCRWM520, CABSCRWM620, CABSCRWS1224, UNISLDSHF19
- Product Type
- Rack
- Product Material
- Aluminium, steel
- 22U
- 60 cm
- 90 cm
- 111 cm
- Limited warranty: - lifetime
- Designed For
StarTech.com 16 Port 1U Rackmount USB PS/2 KVM Switch with OSD | In Stock | £253.47 |
StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - 175lbs / 80kg | In Stock | £92.31 |
StarTech.com 12U 19in Desktop Open Frame 2 Post Rack | In Stock | £41.25 |
StarTech.com 8U Open Frame Wall Mount Equipment Rack - 12in Deep | In Stock | £66.84 |
StarTech.com Universal VESA LCD Monitor Mounting Bracket for 19in Rack or Cabinet | In Stock | £44.03 |
StarTech.com Adjustable Rackmount DIN Rail Kit with Top Hat/Mini/G Rails | In Stock | £76.90 |
StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets | In Stock | £11.90 |
StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £29.91 |
StarTech.com Black Standard Universal Server Rack Cabinet Shelf | In Stock | £30.44 |
StarTech.com 16 Port 1U Rackmount USB KVM Switch with OSD | In Stock | £452.75 |
StarTech.com 50 Pkg M6 Cage Nuts for Server Rack Cabinet | In Stock | £14.09 |
StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £27.99 |
StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £52.23 |
StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £55.25 |
StarTech.com 1U 7in Depth Universal Fixed Rack Mount Shelf – 33lbs / 15kg | In Stock | £25.06 |
StarTech.com 8U Open Frame Wall Mount Equipment Rack - Adjustable Depth | In Stock | £129.80 |
StarTech.com 22in Black Deep Sliding Server Rack Cabinet Shelf | In Stock | £88.98 |
StarTech.com 16 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables | In Stock | £514.22 |
StarTech.com 8 Port 1U Rackmount USB KVM Switch with OSD | In Stock | £273.74 |
StarTech.com 8 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables | In Stock | £309.46 |
StarTech.com 8 Port 1U Rackmount DVI USB KVM Switch | In Stock | £600.89 |
StarTech.com 2U Adjustable Mounting Depth Vented Sliding Rack Mount Shelf – 50lbs / 22.7kg | In Stock | £84.75 |
StarTech.com 1U Fixed 19" Adjustable Depth Universal Server Rack Rails | In Stock | £61.35 |
StarTech.com 2U Fixed 19" Adjustable Depth Universal Server Rack Rails | In Stock | £70.88 |
StarTech.com 3U Fixed 19" Adjustable Depth Universal Server Rack Rails | In Stock | £75.13 |
StarTech.com 12U 36in Knock-Down Server Rack Cabinet with Casters | In Stock | £353.02 |
StarTech.com 1U Adjustable Mounting Depth Rack Mount Shelf - Heavy Duty Shelf - 175lbs / 80kg | In Stock | £71.34 |
StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - Heavy Duty - 250lbs / 113kg | In Stock | £79.75 |
StarTech.com 2U 22in Depth Fixed Rack Mount Shelf - 50lbs / 22kg | In Stock | £55.31 |
StarTech.com 2U 22in Vented Rack Mount Shelf – Fixed Server Rack Cabinet Shelf - 50lbs / 22kg | In Stock | £43.20 |
StarTech.com 2U 16in Universal Vented Rack Mount Cantilever Shelf - Fixed Rack Shelf - 50lbs / 22kg | In Stock | £36.09 |
StarTech.com 2U Rack Mount Cantilever Shelf - Heavy Duty Fixed Server Rack Shelf - 125lbs / 56kg | In Stock | £50.11 |
StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 2.2x3.9in (5.7x10cm) | In Stock | £3.06 |
StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 1.8x3.9in (4.5x10cm) | In Stock | £4.23 |
StarTech.com Multi-Directional Vertical Server Rack Cable Management D-Ring Hook 2.4x3.9in (6x10cm) | In Stock | £6.20 |
StarTech.com 1U Brush Strip Horizontal Server Rack Cable Management Panel | In Stock | £38.24 |
StarTech.com 2U Vented Sliding Rack Shelf w/ Cable Management Arm & Adjustable Depth 50lbs / 22.7kg | In Stock | £154.86 |
StarTech.com 2U Vented Sliding Rack Shelf w/ Cable Management Arm & Adjustable Depth 125lbs / 56.7kg | In Stock | £157.64 |
StarTech.com 24 Port 1U Rackmount Cat 6 110 Patch Panel | In Stock | £46.00 |
StarTech.com 1U Horizontal Finger Duct Rack Cable Management Panel with Cover | In Stock | £17.40 |
StarTech.com 2U Horizontal Finger Duct Rack Cable Management Panel with Cover | In Stock | £22.90 |
StarTech.com 100 Pkg M6 Screws & Cage Nuts | In Stock | £55.20 |
StarTech.com 50 Pkg M6 Screws & Cage Nuts | In Stock | £29.89 |
StarTech.com Portable Server Rack - 9U | In Stock | £261.41 |
StarTech.com 25U 36in Server Rack Cabinet | In Stock | £712.74 |
StarTech.com 100 Pkg M5 Cage Nuts | In Stock | £25.95 |
StarTech.com 50 Pkg M6 Cage Nuts | In Stock | £19.69 |
StarTech.com 100 Pkg M5 Cage Nuts | In Stock | £9.55 |
StarTech.com 50 Pkg M5 Cage Nuts | In Stock | £5.39 |
StarTech.com 100 Pkg M5 Screws & Cage Nuts | In Stock | £52.24 |
StarTech.com 50 Pkg M5 Screws & Cage Nuts | In Stock | £27.56 |
StarTech.com 50 Pkg M5 Mounting Screws | In Stock | £15.48 |
StarTech.com 100 Pkg M5 Mounting Screws | In Stock | £28.96 |
StarTech.com 50 Pkg M6 Mounting Screws | In Stock | £16.16 |
StarTech.com 100 Pkg M6 Cage Nuts | In Stock | £26.89 |
StarTech.com 100 Pkg M6 Cage Nuts | In Stock | £26.45 |
StarTech.com 19in Cable Management Panel | In Stock | £23.58 |
StarTech.com 2-Post Desktop Rack - 8U | In Stock | £34.28 |
StarTech.com 18U Server Rack Enclosure | In Stock | £369.77 |
StarTech.com 6U Wall-Mount Rack Cabinet | In Stock | £148.99 |
StarTech.com 26U Server Rack Enclosure | In Stock | £463.46 |
StarTech.com 9U Wall-Mount Rack Cabinet | In Stock | £174.53 |
StarTech.com 9U Wall-Mount Rack Cabinet | In Stock | £193.99 |
StarTech.com 12U Server Rack Enclosure | In Stock | £330.35 |
StarTech.com 12U Server Rack Enclosure | In Stock | £276.36 |
StarTech.com 15U Server Rack Enclosure | In Stock | £313.10 |
StarTech.com 12U Server Rack Enclosure | In Stock | £375.79 |
StarTech.com 15U Server Rack Cabinet - Includes Casters and Leveling Feet | In Stock | £424.62 |
StarTech.com 18U Server Rack Cabinet - Includes Casters and Leveling Feet | In Stock | £468.65 |
StarTech.com 4U Open Frame Desktop Rack - 2-Post - Weight Cap. 66 lbs | In Stock | £26.53 |
StarTech.com M6 Mounting Screws 50Pack | In Stock | £16.78 |
StarTech.com 42U Server Rack Cabinet | In Stock | £1,227.89 |
