StarTech.com 25U Adjustable Depth 4 Post Open Frame Server Rack Cabinet
Quicklinx: 6B9NWS00 Mfr#: 4POSTRACK25
StarTech.com's DuraRak 25U 4 Post Open Frame Rack/Cabinet provides a durable, open air housing for rackmount servers and networking equipment. The equipment rack/cabinet features heavy gauge mounting rails to ensure a stable installation platform and adjustable posts for flexible installation. The 25U rack is compliant with EIA-RS-310C standards, offering a universal design that's compatible with equipment from popular manufacturers. Plus, the equipment rack is flat-packed, reducing shipping costs and simplifying handling and assembly. The DuraRak 25U 4-Post Open Racks offer a durable housing for valuable equipment.
StarTech.com 25U Open Frame Server Rack - 994lb Capacity - 4 Post Adjustable Depth (18.3" to 39.3") Network/Communications Equipment Rack w/ Casters (4POSTRACK25) - rack - 25U
Rack
Flat black
Height (Rack Units)
25U
57.1 cm x 100 cm x 122.5 cm
39 kg
3-year warranty
P/N: CABCAGENUTS6, CABSCREWM5, CABSCREWM52, CABSCREWM6, CABSCREWM62, CABSCREWS, CABSCREWSM6, CABSCRWM520, CABSCRWM620, CABSCRWS1224
Rack
Height (Rack Units)
25U
57.1 cm
100 cm
122.5 cm
39 kg
Flat black
Weight Limit
450 kg
Limited warranty: - 3 years
6B9N StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - 175lbs / 80kg In Stock £94.63
6B9N StarTech.com 12U 19in Desktop Open Frame 2 Post Rack In Stock £41.63
6B9N StarTech.com 8U Open Frame Wall Mount Equipment Rack - 12in Deep In Stock £68.51
6B9N StarTech.com Universal VESA LCD Monitor Mounting Bracket for 19in Rack or Cabinet In Stock £45.84
6B9N StarTech.com Adjustable Rackmount DIN Rail Kit with Top Hat/Mini/G Rails In Stock £79.46
6B9N StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £30.66
6B9N StarTech.com Black Standard Universal Server Rack Cabinet Shelf In Stock £30.71
6B9N StarTech.com 16 Port 1U Rackmount USB KVM Switch with OSD In Stock £464.07
6B9N StarTech.com 8 Port Rackmount USB VGA KVM Switch w/ Audio (Audio Cables Included) In Stock £351.41
6B9N StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £28.24
6B9N StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £54.39
6B9N StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £57.53
6B9N StarTech.com 1U 7in Depth Universal Fixed Rack Mount Shelf – 33lbs / 15kg In Stock £25.30
6B9N StarTech.com 22in Black Deep Sliding Server Rack Cabinet Shelf In Stock £91.54
6B9N StarTech.com 16 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables In Stock £527.07
6B9N StarTech.com 8 Port 1U Rackmount USB KVM Switch with OSD In Stock £287.42
6B9N StarTech.com 8 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables In Stock £317.20
6B9N StarTech.com 8 Port 1U Rackmount DVI USB KVM Switch In Stock £543.36
6B9N StarTech.com 2U Adjustable Mounting Depth Vented Sliding Rack Mount Shelf – 50lbs / 22.7kg In Stock £86.88
6B9N StarTech.com 4U Black Steel Storage Drawer for 19in Racks and Cabinets In Stock £100.69
6B9N StarTech.com 2U Fixed 19" Adjustable Depth Universal Server Rack Rails In Stock £72.65
6B9N StarTech.com 3U Fixed 19" Adjustable Depth Universal Server Rack Rails In Stock £77.01
6B9N StarTech.com 12U 36in Knock-Down Server Rack Cabinet with Casters In Stock £363.55
6B9N StarTech.com 24 Port 0.5U Cat5e Patch Panel - RJ45 Ethernet Rackmount Cat 5e 110 Patch Panel In Stock £15.50
6B9N StarTech.com 1U Adjustable Mounting Depth Rack Mount Shelf - Heavy Duty Shelf - 175lbs / 80kg In Stock £74.28
6B9N StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - Heavy Duty - 250lbs / 113kg In Stock £81.75
6B9N StarTech.com 2U 22in Depth Fixed Rack Mount Shelf - 50lbs / 22kg In Stock £56.70
6B9N StarTech.com 2U 22in Vented Rack Mount Shelf – Fixed Server Rack Cabinet Shelf - 50lbs / 22kg In Stock £44.28
6B9N StarTech.com 2U 16in Universal Vented Rack Mount Cantilever Shelf - Fixed Rack Shelf - 50lbs / 22kg In Stock £37.00
6B9N StarTech.com 2U Rack Mount Cantilever Shelf - Heavy Duty Fixed Server Rack Shelf - 125lbs / 56kg In Stock £51.38
6B9N StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 2.2x3.9in (5.7x10cm) In Stock £3.06
6B9N StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 1.8x3.9in (4.5x10cm) In Stock £4.68
6B9N StarTech.com Multi-Directional Vertical Server Rack Cable Management D-Ring Hook 2.4x3.9in (6x10cm) In Stock £6.36
6B9N StarTech.com 1U Brush Strip Horizontal Server Rack Cable Management Panel In Stock £38.59
6B9N StarTech.com 2U Vented Sliding Rack Shelf w/ Cable Management Arm & Adjustable Depth 50lbs / 22.7kg In Stock £158.72
6B9N StarTech.com 2U Vented Sliding Rack Shelf w/ Cable Management Arm & Adjustable Depth 125lbs / 56.7kg In Stock £162.18
6B9N StarTech.com 24 Port 1U Rackmount Cat 6 110 Patch Panel In Stock £47.16
6B9N StarTech.com 1U Horizontal Finger Duct Rack Cable Management Panel with Cover In Stock £17.75
6B9N StarTech.com 2U Horizontal Finger Duct Rack Cable Management Panel with Cover In Stock £24.18
6B9N StarTech.com 100 Pkg M6 Screws & Cage Nuts In Stock £56.58
6B9N StarTech.com 50 Pkg M6 Screws & Cage Nuts In Stock £30.63
6B9N StarTech.com Portable Server Rack - 9U In Stock £267.95
6B9N StarTech.com 25U 36in Server Rack Cabinet In Stock £730.55
6B9N StarTech.com 50 Pkg M6 Cage Nuts In Stock £20.19
6B9N StarTech.com 100 Pkg M5 Cage Nuts In Stock £9.55
6B9N StarTech.com 50 Pkg M5 Cage Nuts In Stock £5.39
6B9N StarTech.com 100 Pkg M5 Screws & Cage Nuts In Stock £53.55
6B9N StarTech.com 50 Pkg M5 Screws & Cage Nuts In Stock £28.25
6B9N StarTech.com 100 Pkg M5 Mounting Screws In Stock £29.69
6B9N StarTech.com 50 Pkg M6 Mounting Screws In Stock £16.56
6B9N StarTech.com 100 Pkg M6 Cage Nuts In Stock £27.01
6B9N StarTech.com 100 Pkg M6 Cage Nuts In Stock £27.11
6B9N StarTech.com 19in Cable Management Panel In Stock £24.18
6B9N StarTech.com 2-Post Desktop Rack - 8U In Stock £35.14
6B9N StarTech.com 18U Server Rack Enclosure In Stock £379.01
6B9N StarTech.com 6U Wall-Mount Rack Cabinet In Stock £152.72
6B9N StarTech.com 26U Server Rack Enclosure In Stock £475.05
6B9N StarTech.com 9U Wall-Mount Rack Cabinet In Stock £178.89
6B9N StarTech.com 9U Wall-Mount Rack Cabinet In Stock £198.84
6B9N StarTech.com 12U Server Rack Enclosure In Stock £338.60
6B9N StarTech.com 12U Server Rack Enclosure In Stock £283.26
6B9N StarTech.com 12U Server Rack Enclosure In Stock £393.13
6B9N StarTech.com 10-32 Server Rack Screws and Nuts - 50 Pack - Black - TAA Co In Stock £29.04
6B9N StarTech.com 4U Open Frame Desktop Rack - 2-Post - Weight Cap. 66 lbs In Stock £26.77
6B9N StarTech.com M6 Mounting Screws 50Pack In Stock £16.56
6B9N StarTech.com 42U Server Rack Cabinet In Stock £1,258.59
