This 24in dual drive IDE cable is designed to fit as a new or replacement hard drive or CD-ROM cable in almost any size of computer case. The IDE cable allows you to connect two drives as Master and Slave drives, saving the space of having to use multiple cables to connect the drives.
- StarTech.com Dual Drive Ultra ATA IDE Hard Drive Cable - IDE / EIDE cable - 0.6 m
- IDE / EIDE cable
- Length
- 0.6 m
- Connector
- 40 PIN IDC - female
- Connector (Second End)
- 2 x 40 PIN IDC - female
- Limited lifetime warranty
- Designed For
- P/N: USB2SATAIDE, USB3SSATAIDE
- Storage Cable Type
- IDE / EIDE cable
- Length
- 0.6 m
- Connector
- Designed For
