StarTech.com 20m USB 2.0 Active Extension Cable - M/F
Quicklinx: 887WWS00 Mfr#: USB2AAEXT20M
Length: 20m
£76.40 ex VAT
£91.68 inc VAT
Extend the distance between a computer and a USB 2.0 device by 20 meters. The USB2AAEXT20M 20-meter Active USB 2.0 Extension Cable, offers one USB type-A (male) connector and one USB type-A (female) connector, and provides an active extension of USB 2.0 devices of up to 20-meters (66-feet).
An all-in-one cable for overcoming distance restrictions as well as power source limitations, the active USB 2.0 extension cable incorporates bus-powered active circuitry to ensure performance beyond the length limits of standard USB cables. Up to 2 of these cables can be daisy-chained together, allowing the connection to be extended a total of 40-meters. If necessary, the USB device can be powered from a wall outlet using the Universal AC power adapter provided with the cable.
  • Durable construction
    The cable features a robust shielded design, which minimizes interference and increases overall durability, ensuring a reliable connection for all devices.
  • Active signal regeneration
    With built-in signal regeneration technology, this cable maintains high-quality data transfer over long distances, ensuring minimal latency and performance.
  • Versatile compatibility
    Designed to comply with USB 2.0 standards, this cable is compatible with a wide range of USB devices, making it a versatile solution for applications.
StarTech.com 20m USB 2.0 Active Extension Cable - M/F - USB extension cable - USB (M) to USB (F) - USB 2.0 - 66 ft - active - black - USB2AAEXT20M - USB extension cable - USB to USB - 20 m
USB extension cable
Shielded
Active cable (signal regeneration)
Length
20 m
Connector
4 pin USB Type A - male
Connector (Second End)
4 pin USB Type A - female
USB / USB 2.0
P/N: SVA5H2NEUA, UUSBOTG
USB extension cable
Shielded
Plated Connector
Nickel
Length
20 m
Connector
USB / USB 2.0, FCC, RoHS
887W StarTech.com 10ft USB 2.0 Extension Cable A to A - M/F In Stock £5.00
887W StarTech.com 3 ft Black USB 2.0 Extension Cable A to A - M/F In Stock £4.06
887W StarTech.com 6 ft Black USB 2.0 Extension Cable A to A - M/F In Stock £4.19
887W StarTech.com 20m USB 2.0 Active Extension Cable - M/F In Stock £76.40
887W StarTech.com 15m USB 2.0 Active Extension Cable - M/F In Stock £61.53
887W StarTech.com 1m (3ft) White Apple 8-pin Lightning Connector to USB Cable for iPhone / iPod / iPad In Stock £14.23
887W StarTech.com 10m USB 2.0 Active Extension Cable - M/F In Stock £53.10
887W StarTech.com 25m USB 2.0 Active Extension Cable - M/F In Stock £95.29
887W StarTech.com 5m USB 2.0 Active Extension Cable - M/F In Stock £37.96
887W StarTech.com DC Power Adapter - 5V, 2A In Stock £9.91
887W StarTech.com USB Extender Hub, 24m, USB 2.0 In Stock £117.90
887W StarTech.com USB Extender Hub, 10m, USB 3.0 In Stock £104.43
Length: 20m
