StarTech.com 20m Coax High Resolution Monitor VGA Cable - HD15 M/M
Quicklinx: 7P0GWS00 Mfr#: MXTMMHQ20M
Length: 20m
16 in stock
£50.35 ex VAT
£60.42 inc VAT
Connect your VGA monitor with the highest quality connection available. This 20-meter high resolution VGA monitor cable is designed to provide the highest video quality possible through a VGA connection.
Ideally suited for high resolution VGA applications, this high quality male-to-male coaxial VGA cable eliminates the picture "ghosting" and fuzzy images that are inherent to non-coaxial cables, while providing superior EMI interference protection by using ferrite cores near the connector ends.
StarTech.com 20m Coax High Resolution Monitor VGA Cable HD15 M/M - VGA cable - 20 m
VGA cable
Triple shielded twisted pair coaxial
Molded
Length
20 m
Connector
HD-15 (VGA) - male
Connector (Second End)
HD-15 (VGA) - male
RoHS
VGA cable
Shielding Material
American Wire Gauge (AWG)
28
Plated Connector
Nickel
Molded
Length
20 m
Connector
RoHS
7P0G StarTech.com Right Angle VGA to VGA Cable Adapter Type 1 - M/F In Stock £6.13
7P0G StarTech.com 10m Coax High Resolution Monitor VGA Cable - HD15 M/M In Stock £23.32
7P0G StarTech.com 15m Coax High Resolution Monitor VGA Cable - HD15 M/M In Stock £36.89
7P0G StarTech.com 20m Coax High Resolution Monitor VGA Cable - HD15 M/M In Stock £50.35
Length: 20m
Price Range Ex VAT: 50 - 100
