Connect your VGA monitor with the highest quality connection available. This 10m high resolution VGA monitor cable is designed to provide the highest video quality possible through VGA. Ideally suited for high resolution VGA applications, this high quality male-to-male coaxial VGA cable eliminates the picture "ghosting" and fuzzy images that are inherent to non-coaxial cables, while providing superior EMI interference protection by using ferrite cores near the connector ends.
Reliable signal quality
The triple shielded twisted pair coaxial technology ensures robust performance, reducing interference and maintaining high signal integrity for clear video quality. -
Durable construction
The molded connectors offer a strong and secure connection, enhancing the lifespan of the cable while preventing wear and tear. -
Environmentally friendly
This VGA cable complies with RoHS standards, minimizing the impact on the environment while delivering dependable connectivity. -
Effective conductivity
Nickel plated connectors enable excellent conductivity, ensuring reliable performance for all your video display needs.
- StarTech 10m Coax High Resolution Monitor VGA Cable HD15 M/M - VGA cable - 10 m
- VGA cable
- Technology
- Triple shielded twisted pair coaxial
- Molded
- Cable Length
- 10 m
- Connector
- HD-15 (VGA) - male
- Connector (Second End)
- RoHS
- Black
- Limited lifetime warranty
- VGA cable
- Technology
- Shielding Material
- Aluminum mylar foil with braid
- American Wire Gauge (AWG)
- 28
- Plated Connector
- Nickel
- Molded
- Cable Length
- 10 m
- Black
- Connector
- 15 pin HD D-Sub (HD-15) - male
- RoHS
StarTech.com Slimline Adapter HDDB15 F/F | In Stock | £5.33 |
StarTech.com 15m Coax High Resolution Monitor VGA Cable - HD15 M/M | In Stock | £40.88 |
StarTech.com 2m Coax High Resolution Monitor VGA Video Cable - HD15 to HD15 M/M | In Stock | £7.32 |
StarTech.com 3m Coax High Resolution Monitor VGA Video Cable - HD15 to HD15 M/M | In Stock | £10.25 |
