StarTech.com 20m / 65 ft Active USB 2.0 A to B Cable - M/M
Quicklinx: 8NV6WS00 Mfr#: USB2HAB65AC
Length: 20m
Select:
26 in stock
£29.16 ex VAT
£34.99 inc VAT
Extend the distance between your USB 2.0 devices by up to 65ft. The USB2HAB65AC 65ft/20m USB A to B cable incorporates bus-powered active circuitry, which enables it to perform beyond the 5-meter limit of a standard USB cable.
The longer connection provides enough cable length to connect your USB 2.0 peripherals up to 20m away from your PC, Laptop or Server, allowing you to position your devices as needed.
This active USB 2.0 cable is designed with top quality materials for high durability.
StarTech.com 20m / 65 ft Active USB 2.0 A to B Cable - M/M - USB cable - 20 m
USB cable
Shielded
Length
20 m
Connector
4 pin USB Type B - male
Connector (Second End)
4 pin USB Type A - male
USB / USB 2.0
P/N: ICUSB232D
USB cable
Shielded
American Wire Gauge (AWG)
28
Plated Connector
Nickel
Length
20 m
Connector
USB / USB 2.0, FCC, RoHS
P/N: ICUSB232D
8NV6 StarTech.com 10m/30ft Active USB 2.0 A to B Cable - M/M In Stock £16.91
8NV6 StarTech.com 20m / 65 ft Active USB 2.0 A to B Cable - M/M In Stock £29.16
Length: 20m
Price Range Ex VAT: 0 - 50
