Connect USB 2.0 devices up to 50ft away, with no signal loss. The USB2HAB50AC 50ft / 15m USB A to B cable incorporates bus-powered active circuitry, which enables it to perform beyond the 5-meter limit of a standard USB cable.
The longer connection provides enough cable length to connect your USB 2.0 peripherals up to 15m away from your PC, Laptop or Server, allowing you to position your devices as needed.
This active USB 2.0 cable is designed with top quality materials for high durability.
Reliable signal transmission
The active cable design includes technology for signal regeneration, enabling effective communication over a distance of 15 m or 50 ft without signal loss, ensuring quality connections for USB devices. -
Durable construction
With nickel-plated connectors and a double shielded build, this cable offers enhanced durability and resistance against wear and tear while maintaining quality connectivity and performance. -
Versatile compatibility
This USB cable adheres to USB 2.0 standards, allowing compatibility with a wide range of devices such as printers, scanners, and external hard drives, making it a practical choice for diverse setups.
- StarTech.com 15m / 50 ft Active USB 2.0 A to B Cable - Long 15 m USB Cable - 50 ft USB Printer Cable - 1x USB A (M), 1x USB B (M) - Black (USB2HAB50AC) - USB cable - USB Type B to USB - 15 m
- USB cable
- Technology
- Double shielded
- Active cable (signal regeneration)
- Length
- 15 m
- Connector
- 4 pin USB Type B - male
- Connector (Second End)
- 4 pin USB Type A - male
- USB / USB 2.0
- Black
- 2-year warranty
- Designed For
- P/N: ICUSB232D
- USB cable
- Technology
- Double shielded
- American Wire Gauge (AWG)
- 24
- Plated Connector
- Nickel
- Length
- 15 m
- Black
- Connector
- USB / USB 2.0, FCC, RoHS
- 2-year warranty
- Designed For
- P/N: ICUSB232D
StarTech.com Mountable 4 Port Rugged Industrial USB Hub | In Stock | £60.83 |
StarTech.com 1 ft Panel Mount USB Cable B to B - F/M | In Stock | £5.68 |
StarTech.com Mountable Rugged Industrial 7 Port USB Hub | In Stock | £90.79 |
StarTech.com 10m/30ft Active USB 2.0 A to B Cable - M/M | In Stock | £19.71 |
StarTech.com 20m / 65 ft Active USB 2.0 A to B Cable - M/M | In Stock | £37.87 |
StarTech.com 15m / 50 ft Active USB 2.0 A to B Cable - M/M | In Stock | £32.59 |
StarTech.com 3 ft Panel Mount USB Cable B to B - F/M | In Stock | £5.69 |
