Extend the distance between your USB 2.0 devices by up to 65ft. The USB2HAB65AC 65ft/20m USB A to B cable incorporates bus-powered active circuitry, which enables it to perform beyond the 5-meter limit of a standard USB cable.
The longer connection provides enough cable length to connect your USB 2.0 peripherals up to 20m away from your PC, Laptop or Server, allowing you to position your devices as needed.
This active USB 2.0 cable is designed with top quality materials for high durability.
- StarTech.com 20m / 65 ft Active USB 2.0 A to B Cable - Long 20 m USB Cable - 20m USB Printer Cable - 1x USB A (M), 1x USB B (M) - Black (USB2HAB65AC) - USB cable - USB Type B to USB - 20 m
- USB cable
- Technology
- Shielded
- Length
- 20 m
- Connector
- 4 pin USB Type B - male
- Connector (Second End)
- 4 pin USB Type A - male
- USB / USB 2.0
- Black
- 2-year warranty
- Designed For
- P/N: ICUSB232D
- USB cable
- Technology
- Shielded
- American Wire Gauge (AWG)
- 28
- Plated Connector
- Nickel
- Length
- 20 m
- Black
- Connector
- USB / USB 2.0, FCC, RoHS
- 2-year warranty
- Designed For
- P/N: ICUSB232D
StarTech.com 10m/30ft Active USB 2.0 A to B Cable - M/M | In Stock | £19.93 |
