Extend the distance between your USB 2.0 devices by up to 65ft. The USB2HAB65AC 65ft/20m USB A to B cable incorporates bus-powered active circuitry, which enables it to perform beyond the 5-meter limit of a standard USB cable.
The longer connection provides enough cable length to connect your USB 2.0 peripherals up to 20m away from your PC, Laptop or Server, allowing you to position your devices as needed.
This active USB 2.0 cable is designed with top quality materials for high durability.
Reliable connectivity
This cable supports USB 2.0 standards and ensures stable data transmission over a distance of 20 m. -
Enhanced durability
Nickel-plated connectors contribute to a stronger connection and longevity of use in various environments. -
Interference reduction
Shielded technology protects against signal degradation, promoting secure and consistent performance. -
Safety compliant
Meets FCC and RoHS standards, ensuring safe use while being environmentally friendly. -
Efficient power transfer
The 28 AWG construction enables effective power and data transfer, suitable for demanding applications.
 - StarTech.com 20m / 65 ft Active USB 2.0 A to B Cable - Long 20 m USB Cable - 20m USB Printer Cable - 1x USB A (M), 1x USB B (M) - Black (USB2HAB65AC) - USB cable - USB Type B to USB - 20 m
 - USB cable
- Technology
 - Shielded
- Length
 - 20 m
- Connector
 - 4 pin USB Type B - male
- Connector (Second End)
 - 4 pin USB Type A - male
 - USB / USB 2.0
 - Black
 - 2-year warranty
- Designed For
 - P/N: ICUSB232D
 - USB cable
- Technology
 - Shielded
- American Wire Gauge (AWG)
 - 28
- Plated Connector
 - Nickel
- Length
 - 20 m
 - Black
- Connector
 - USB / USB 2.0, FCC, RoHS
 - 2-year warranty
- Designed For
 - P/N: ICUSB232D
                        StarTech.com 10m/30ft Active USB 2.0 A to B Cable - M/M | In Stock | £19.36 |
                        StarTech.com 20m / 65 ft Active USB 2.0 A to B Cable - M/M | In Stock | £37.53 |
                        StarTech.com 15m / 50 ft Active USB 2.0 A to B Cable - M/M | In Stock | £32.53 |
