This USB 3.2/3.1 Gen 2 10Gbps USB-C cable lets you connect your USB Type-C devices for syncing, charging and powering your devices.
The cable is also compatible with Thunderbolt 3 ports, which means you can charge and sync your USB-C mobile devices using your Thunderbolt 3 laptop.
                Power your USB-C devicesWith up to 5A (100W) of power delivery, you can power a USB-C laptop, such as your Apple MacBook or Microsoft Surface Book. Simply connect the cable to your USB-C laptop and to a USB-C wall charger. You can use this USB Type-C cable to power your USB-C hard drive from the USB-C port on your laptop. This cable is great for close-range connections to charge and sync your USB Type-C mobile devices with your laptop. You can also use the cable to charge your USB-C devices from a USB-C wall charger, car charger or power bank. It's the ideal cable for commuters for in-car use or to reduce clutter when syncing with your laptop.
                Deliver 8K video with DisplayPort 1.4 Alt ModeThe cable supports 8K 30Hz video with DisplayPort 1.4 and is backward compatible for connecting your docking station or laptop to a monitor that supports 4K or 1080p resolutions.
                Keep as a spare while travelingReplace the USB-C charging cable that came with your device, or keep one as a spare while you're traveling, so that all of your devices will be ready to use whenever you need them while you're on the road.
- StarTech.com 20" (50cm) USB C Cable 10Gbps, USB 3.1/3.2 Gen 2 Type-C Cable, 100W (5A) Power Delivery Charging, DP Alt Mode, USB-C to C Cord, For USB-C Laptop, Phone, Device, Charge/Sync - Thunderbolt 3 Compatible (USB31CCV50CM) - USB-C cable - 24 pin USB-C to 24 pin USB-C - 50 cm
- USB-C cable
- 4K support, Power Delivery (PD) technology, 10 Gbps data rate, DisplayPort Alternate Mode support, EMI protection, outer diameter 4.8 mm
- Length
- 50 cm
- Connector
- 24 pin USB-C - male
- Connector (Second End)
- USB 3.2 Gen 2 / DisplayPort 1.4 /Thunderbolt 3
- Black, grey
- 2-year warranty
- Designed For
- P/N: DK30C2DAGPD, DK30C2HAGPD
- USB-C cable
- Shielding Material
- Aluminum mylar foil with braid
- Jacket Material
- Thermoplastic elastomer (TPE)
- American Wire Gauge (AWG)
- 30/32
- Plated Connector
- Nickel
- Length
- 50 cm
- Black, grey
- Connector
- USB 3.2 Gen 2 / DisplayPort 1.4 /Thunderbolt 3, RoHS, WEEE
- Shipping Width
- 22 cm
- Shipping Depth
- 12.8 cm
- Shipping Height
- 14 cm
- Shipping Weight
- 88 g
- 2-year warranty
- Designed For
|  | StarTech.com Rugged Right Angle USB-C Cable 1m | In Stock | £27.51 |
|  | StarTech.com 3m Active USB-C Cable, USB 3.2 | In Stock | £46.67 |
