Store your equipment in this sturdy steel rack with casters for mobility. Store your server, network and telecommunications equipment in this sturdy 42U rack. With a 2-post design, the rack saves floor space and its dual-post, open-depth design makes it broadly compatible with longer equipment.
The 2-post rack features four swiveling casters, so you can easily move it around in your server room, office or studio. It's easy to reposition or relocate the rack in order to connect your rack-mounted equipment to other devices throughout your workspace.
The durable dual-post server rack is made of heavy-gauge steel, instead of aluminum, to ensure a stable installation platform. The rack supports a static loading capacity of up to 660 lb. (300 kg), and it's compliant with several industry rack standards (EIA/ECA-310, IEC 60297, DIN 41494), to provide a stable platform that eliminates the need for concrete mounting kits.
You can easily mount your ANSI/EIA RS-310-D compliant network equipment to the rack without using additional hardware. It features square mounting holes on the frame and a universal design that's compatible with most rack equipment.
Maximum portability
The 2-post rack features four swiveling casters, so you can easily move it around in your server room, office or studio. It's easy to reposition or relocate the rack in order to connect your rack-mounted equipment to other devices throughout your workspace. -
High durability
The durable dual-post server rack is made of heavy-gauge steel, instead of aluminum, to ensure a stable installation platform. The rack supports a static loading capacity of up to 600 lb. (272 kg), and it's compliant with several industry rack standards (EIA/ECA-310, IEC 60297, DIN 41494), to provide a stable platform that eliminates the need for concrete mounting kits. -
Wide compatibility
You can easily mount your ANSI/EIA RS-310-D compliant network equipment to the rack without using additional hardware. It features square mounting holes on the frame and a universal design that's compatible with most rack equipment. The 2POSTRACK42 is backed by a StarTech.com 2-year warranty and free lifetime technical support.
 - StarTech.com 42U Mobile Open Frame Network Rack with Wheels- 663lbs - 2 Post 19" Portable Rack for Computer, AV, Media, IT Equipment (2POSTRACK42) - rack - 42U - TAA Compliant
- Product Type
 - Rack
- Rack Type
 - Open frame
- Package Content
 - 30 M6 screws, 32 M6 cage nuts, 2 bottom supporting beams, 2 vertical rails, 2 horizontal rails, 2 angle support beams, 2 x 2" heavy-duty casters, 26 M6 nuts, 16 M6 caster screws, 32 M6 screws with plastic washers, 4mm allen key
- Height (Rack Units)
 - 42U
- Product Material
 - Steel
 - 4 swivel casters
- Telescopic Handle / Wheels
- TAA Compliant
 - 2-year warranty
- Designed For
 - P/N: CABCAGENT62B, CABCAGENTS62, CABCAGENUT2B, CABCAGENUT6B, CABCAGENUTS2, CABCAGENUTSB, CABSCREWM52B, CABSCREWM5B, CABSCREWM62B, CABSCREWM6B, CABSCREWSB, CABSCREWSM5, CABSCREWSM5B, CABSCREWSM62, CABSCREWSM6B, CABSCRWS1224, CABSCRWSM62B
- Product Type
 - Rack
- Rack Type
 - Open frame
- Product Material
 - Steel
- Package Content
 - 42U
- Weight Limit
 - 544 kg
- Mounting Kit
 - Included
 - 4 swivel casters
- TAA Compliant
 - Limited warranty: - 2 years
- Designed For
                        StarTech.com Universal VESA LCD Monitor Mounting Bracket for 19in Rack or Cabinet | In Stock | £44.03 |
                        StarTech.com Adjustable Rackmount DIN Rail Kit with Top Hat/Mini/G Rails | In Stock | £76.74 |
                        StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets | In Stock | £11.90 |
                        StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £29.91 |
                        StarTech.com Black Standard Universal Server Rack Cabinet Shelf | In Stock | £30.44 |
                        StarTech.com 16 Port 1U Rackmount USB KVM Switch with OSD | In Stock | £452.75 |
                        StarTech.com 50 Pkg M6 Cage Nuts for Server Rack Cabinet | In Stock | £14.39 |
                        StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £27.99 |
                        StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £52.23 |
                        StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £55.25 |
                        StarTech.com 1U 7in Depth Universal Fixed Rack Mount Shelf – 33lbs / 15kg | In Stock | £25.06 |
                        StarTech.com 16 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables | In Stock | £514.22 |
                        StarTech.com 8 Port 1U Rackmount USB KVM Switch with OSD | In Stock | £273.74 |
                        StarTech.com 8 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables | In Stock | £309.46 |
                        StarTech.com 8 Port 1U Rackmount DVI USB KVM Switch | In Stock | £600.89 |
                        StarTech.com 24 Port 0.5U Cat5e Patch Panel - RJ45 Ethernet Rackmount Cat 5e 110 Patch Panel | In Stock | £17.22 |
                        StarTech.com 2U 22in Depth Fixed Rack Mount Shelf - 50lbs / 22kg | In Stock | £55.31 |
                        StarTech.com 2U 22in Vented Rack Mount Shelf – Fixed Server Rack Cabinet Shelf - 50lbs / 22kg | In Stock | £43.20 |
                        StarTech.com 2U 16in Universal Vented Rack Mount Cantilever Shelf - Fixed Rack Shelf - 50lbs / 22kg | In Stock | £36.09 |
                        StarTech.com 2U Rack Mount Cantilever Shelf - Heavy Duty Fixed Server Rack Shelf - 125lbs / 56kg | In Stock | £50.11 |
                        StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 2.2x3.9in (5.7x10cm) | In Stock | £3.06 |
                        StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 1.8x3.9in (4.5x10cm) | In Stock | £4.21 |
                        StarTech.com Multi-Directional Vertical Server Rack Cable Management D-Ring Hook 2.4x3.9in (6x10cm) | In Stock | £6.20 |
                        StarTech.com 1U Brush Strip Horizontal Server Rack Cable Management Panel | In Stock | £38.24 |
                        StarTech.com 24 Port 1U Rackmount Cat 6 110 Patch Panel | In Stock | £46.00 |
                        StarTech.com 1U Horizontal Finger Duct Rack Cable Management Panel with Cover | In Stock | £17.31 |
                        StarTech.com 2U Horizontal Finger Duct Rack Cable Management Panel with Cover | In Stock | £22.90 |
                        StarTech.com 100 Pkg M6 Screws & Cage Nuts | In Stock | £55.20 |
                        StarTech.com 50 Pkg M6 Screws & Cage Nuts | In Stock | £29.89 |
                        StarTech.com 50 Pkg M6 Cage Nuts | In Stock | £19.69 |
                        StarTech.com 100 Pkg M5 Cage Nuts | In Stock | £9.55 |
                        StarTech.com 50 Pkg M5 Cage Nuts | In Stock | £5.39 |
                        StarTech.com 100 Pkg M5 Screws & Cage Nuts | In Stock | £52.24 |
                        StarTech.com 50 Pkg M5 Screws & Cage Nuts | In Stock | £27.56 |
                        StarTech.com 50 Pkg M5 Mounting Screws | In Stock | £15.48 |
                        StarTech.com 100 Pkg M5 Mounting Screws | In Stock | £30.19 |
                        StarTech.com 50 Pkg M6 Mounting Screws | In Stock | £16.16 |
                        StarTech.com 100 Pkg M6 Cage Nuts | In Stock | £26.84 |
                        StarTech.com 100 Pkg M6 Cage Nuts | In Stock | £26.45 |
                        StarTech.com 19in Cable Management Panel | In Stock | £23.58 |
                        StarTech.com M6 Rack Screws and Cage Nuts | In Stock | £15.09 |
                        StarTech.com Vented 1U Rack Shelf - 10in | In Stock | £20.54 |
                        StarTech.com 2 Post Server Rack Shelf - Center Mount - Black | In Stock | £57.26 |
                        StarTech.com M6 Mounting Screws 50Pack | In Stock | £16.74 |
