StarTech.com 16 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables
Quicklinx: 7P2YWS00 Mfr#: SV1631DUSBUK
Type: KVM switch
Ports: 16
Connectivity: KVM
Hurry, only 3 left in stock!
£527.07 ex VAT
£632.48 inc VAT
The SV1631DUSBUK 16 Port 1U Rack Mount USB KVM Switch Kit with OSD and Cables offers a well-appointed KVM switch that includes all of the cables and accessories required to connect to 16 servers or PCs right out of the box, making setup convenient and simple.
The USB KVM delivers a dependable computer management tool that allows you to control up to 16 USB-connected computers from a single keyboard, mouse and display, providing maximum control through hotkey command-based switching or front panel push-buttons, with the added configurability and convenience of an On-Screen Display.
A suitable addition to server room operations, the 16-port switch can be rackmounted into 1U of cabinet space and can be cascaded with multiple KVM switches to enable control of up to 136 computers from this single switch.
  • Versatile Connectivity
    This KVM switch supports both USB connections for keyboards and mice, as well as VGA for video, allowing for compatibility with a wide range of devices.
  • High Performance
    With a maximum video resolution of 1920 x 1440 and a refresh rate of 60 Hz, users can expect visuals for all applications.
  • Reliable Operation
    Designed to work in various environmental conditions, this KVM switch operates effectively in temperatures ranging from 5°C to 40°C and can handle humidity levels of 0 to 80%.
  • Easy Management
    The On-Screen Display feature simplifies the process of switching between devices, allowing users to manage multiple systems with ease.
  • Compliant and Safe
    Meets FCC and RoHS standards to ensure environmental safety, making it a responsible choice for both personal and professional use.
StarTech.com 16 Port Rackmount USB KVM Switch Kit with OSD and Cables - 1U (SV1631DUSBUK) - KVM switch - 16 ports
KVM switch - 16 ports - cascadable
Enclosure Type
1U
Subtype
KVM
Ports
16 x KVM port(s)
KVM Users Qty
1 local user
On-Screen Display
AC 120/230 V
54 cm x 18 cm x 4.5 cm
3.1 kg
3-year warranty
P/N: 2POSTRACK12, 2POSTRACK16, 2POSTRACK42, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKHD, RACKCOND17HD, RK1233BKM, RK1833BKM, RK2236BKF, RK2433BKM, RK2536BKF, RK2537BKM, RK3236BKF, RK4236BKB, RK4242BK24, RK4242BK30, RKCONS1701, RKCONS17HD, SVA9M2NEUA, SVUSBVGA10, SVUSBVGA6
Enclosure Type
Desktop 1U
Subtype
KVM
Ports
16 x KVM port(s)
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
USB
Max Resolution
1920 x 1440 @ 60 Hz
On-Screen Display
Status Indicators
Port status, power
16 x KVM HD-15 , 1 x VGA HD-15 , 1 x keyboard (USB) Type A , 1 x mouse (USB) Type A
External power adapter
AC 120/230 V
16 x keyboard / mouse / video cable - 1.8 m
Rack Mounting Kit
Included
FCC, RoHS
54 cm
18 cm
4.5 cm
3.1 kg
Limited warranty - 3 years
5 °C
0 - 80%
P/N: 2POSTRACK12, 2POSTRACK16, 2POSTRACK42, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKBK, 4POSTRACKHD, 7236CABINET, RACKCOND17HD, RK1233BKM, RK1833BKM, RK2236BKF, RK2433BKM, RK2536BKF, RK2537BKM, RK3236BKF, RK4236BK, RK4236BKB, RK4242BK, RK4242BK24, RK4242BK30, RKCONS1701, RKCONS17HD, SVA9M2NEUA, SVECONUS10, SVECONUS15, SVECONUS6, SVUSBVGA10, SVUSBVGA6
7P2Y StarTech.com 10 ft Ultra Thin USB VGA 2-in-1 KVM Cable In Stock £9.47
7P2Y StarTech.com 4 Port Professional VGA USB KVM Switch with Hub In Stock £83.88
7P2Y StarTech.com 1U 19in Steel Vertical Wall Mount Equipment Rack Bracket In Stock £36.68
7P2Y StarTech.com 2U 19in Steel Vertical Wall Mount Equipment Rack Bracket In Stock £35.52
7P2Y StarTech.com 10 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £5.37
7P2Y StarTech.com 15 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £5.56
7P2Y StarTech.com 3 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £2.97
7P2Y StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £3.97
7P2Y StarTech.com 16 Port 1U Rackmount USB KVM Switch with OSD In Stock £464.07
7P2Y StarTech.com 16 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables In Stock £527.07
7P2Y StarTech.com 8 Port 1U Rackmount USB KVM Switch with OSD In Stock £280.59
7P2Y StarTech.com 8 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables In Stock £317.20
7P2Y StarTech.com 8 Port 1U Rackmount DVI USB KVM Switch In Stock £543.36
7P2Y StarTech.com 6 ft Ultra-Thin USB VGA 2-in-1 KVM Cable In Stock £7.40
7P2Y StarTech.com 1m Black SuperSpeed USB 3.0 Extension Cable A to A - M/F In Stock £6.71
7P2Y StarTech.com 2m Black SuperSpeed USB 3.0 Extension Cable A to A - M/F In Stock £7.11
7P2Y StarTech.com 2-port Dual VGA KVM Switch In Stock £67.05
7P2Y StarTech.com DC Power Adapter - 9V, 2A In Stock £12.21
7P2Y StarTech.com 8-Port DisplayPort KVM Switch In Stock £408.00
7P2Y StarTech.com 8-Port HDMI KVM Switch In Stock £502.49
Type: KVM switch
Ports: 16
Connectivity: KVM
Price Range Ex VAT: £500 - £750
