StarTech.com 2-Post Server Rack - 42U
Quicklinx: BWG3WS00 Mfr#: 2POSTRACK42
Hurry, only 3 left in stock!
£147.91 ex VAT
£177.49 inc VAT
Store your equipment in this sturdy steel rack with casters for mobility. Store your server, network and telecommunications equipment in this sturdy 42U rack. With a 2-post design, the rack saves floor space and its dual-post, open-depth design makes it broadly compatible with longer equipment.
The 2-post rack features four swiveling casters, so you can easily move it around in your server room, office or studio. It's easy to reposition or relocate the rack in order to connect your rack-mounted equipment to other devices throughout your workspace.
The durable dual-post server rack is made of heavy-gauge steel, instead of aluminum, to ensure a stable installation platform. The rack supports a static loading capacity of up to 660 lb. (300 kg), and it's compliant with several industry rack standards (EIA/ECA-310, IEC 60297, DIN 41494), to provide a stable platform that eliminates the need for concrete mounting kits.
You can easily mount your ANSI/EIA RS-310-D compliant network equipment to the rack without using additional hardware. It features square mounting holes on the frame and a universal design that's compatible with most rack equipment.
  • Maximum portability
  • High durability
    The durable dual-post server rack is made of heavy-gauge steel, instead of aluminum, to ensure a stable installation platform. The rack supports a static loading capacity of up to 600 lb. (272 kg), and it's compliant with several industry rack standards (EIA/ECA-310, IEC 60297, DIN 41494), to provide a stable platform that eliminates the need for concrete mounting kits.
  • Wide compatibility
    You can easily mount your ANSI/EIA RS-310-D compliant network equipment to the rack without using additional hardware. It features square mounting holes on the frame and a universal design that's compatible with most rack equipment. The 2POSTRACK42 is backed by a StarTech.com 2-year warranty and free lifetime technical support.
StarTech.com 42U Mobile Open Frame Network Rack with Wheels- 663lbs - 2 Post 19" Portable Rack for Computer, AV, Media, IT Equipment (2POSTRACK42) - rack - 42U - TAA Compliant
Rack
Rack Type
Open frame
Package Content
30 M6 screws, 32 M6 cage nuts, 2 bottom supporting beams, 2 vertical rails, 2 horizontal rails, 2 angle support beams, 2 x 2" heavy-duty casters, 26 M6 nuts, 16 M6 caster screws, 32 M6 screws with plastic washers, 4mm allen key
Height (Rack Units)
42U
Product Material
Steel
4 swivel casters
Telescopic Handle / Wheels
TAA Compliant
P/N: CABCAGENT62B, CABCAGENTS62, CABCAGENUT2B, CABCAGENUT6B, CABCAGENUTS2, CABCAGENUTSB, CABSCREWM52B, CABSCREWM5B, CABSCREWM62B, CABSCREWM6B, CABSCREWSB, CABSCREWSM5, CABSCREWSM5B, CABSCREWSM62, CABSCREWSM6B, CABSCRWS1224, CABSCRWSM62B
Rack
Rack Type
Open frame
Product Material
Steel
Package Content
Height (Rack Units)
42U
Weight Limit
544 kg
Mounting Kit
Included
4 swivel casters
TAA Compliant
Limited warranty: - 2 years
BWG3 StarTech.com Universal VESA LCD Monitor Mounting Bracket for 19in Rack or Cabinet In Stock £45.84
BWG3 StarTech.com Adjustable Rackmount DIN Rail Kit with Top Hat/Mini/G Rails In Stock £79.45
BWG3 StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets In Stock £12.20
BWG3 StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £30.66
BWG3 StarTech.com Black Standard Universal Server Rack Cabinet Shelf In Stock £30.71
BWG3 StarTech.com 16 Port 1U Rackmount USB KVM Switch with OSD In Stock £464.07
BWG3 StarTech.com 8 Port Rackmount USB VGA KVM Switch w/ Audio (Audio Cables Included) In Stock £351.41
BWG3 StarTech.com 50 Pkg M6 Cage Nuts for Server Rack Cabinet In Stock £14.44
BWG3 StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £28.24
BWG3 StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £54.39
BWG3 StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £57.53
BWG3 StarTech.com 1U 7in Depth Universal Fixed Rack Mount Shelf – 33lbs / 15kg In Stock £25.33
BWG3 StarTech.com 16 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables In Stock £527.07
BWG3 StarTech.com 8 Port 1U Rackmount USB KVM Switch with OSD In Stock £280.59
BWG3 StarTech.com 8 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables In Stock £317.20
BWG3 StarTech.com 8 Port 1U Rackmount DVI USB KVM Switch In Stock £543.36
BWG3 StarTech.com 24 Port 0.5U Cat5e Patch Panel - RJ45 Ethernet Rackmount Cat 5e 110 Patch Panel In Stock £15.50
BWG3 StarTech.com 2U 22in Depth Fixed Rack Mount Shelf - 50lbs / 22kg In Stock £56.70
BWG3 StarTech.com 2U 22in Vented Rack Mount Shelf – Fixed Server Rack Cabinet Shelf - 50lbs / 22kg In Stock £44.28
BWG3 StarTech.com 2U 16in Universal Vented Rack Mount Cantilever Shelf - Fixed Rack Shelf - 50lbs / 22kg In Stock £37.00
BWG3 StarTech.com 2U Rack Mount Cantilever Shelf - Heavy Duty Fixed Server Rack Shelf - 125lbs / 56kg In Stock £51.38
BWG3 StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 2.2x3.9in (5.7x10cm) In Stock £3.06
BWG3 StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 1.8x3.9in (4.5x10cm) In Stock £4.24
BWG3 StarTech.com Multi-Directional Vertical Server Rack Cable Management D-Ring Hook 2.4x3.9in (6x10cm) In Stock £6.36
BWG3 StarTech.com 1U Brush Strip Horizontal Server Rack Cable Management Panel In Stock £38.59
BWG3 StarTech.com 24 Port 1U Rackmount Cat 6 110 Patch Panel In Stock £47.16
BWG3 StarTech.com 1U Horizontal Finger Duct Rack Cable Management Panel with Cover In Stock £17.48
BWG3 StarTech.com 2U Horizontal Finger Duct Rack Cable Management Panel with Cover In Stock £23.11
BWG3 StarTech.com 100 Pkg M6 Screws & Cage Nuts In Stock £56.58
BWG3 StarTech.com 50 Pkg M6 Screws & Cage Nuts In Stock £30.63
BWG3 StarTech.com 50 Pkg M6 Cage Nuts In Stock £20.19
BWG3 StarTech.com 100 Pkg M5 Cage Nuts In Stock £30.81
BWG3 StarTech.com 50 Pkg M5 Cage Nuts In Stock £5.39
BWG3 StarTech.com 50 Pkg M5 Screws & Cage Nuts In Stock £28.25
BWG3 StarTech.com 100 Pkg M5 Mounting Screws In Stock £29.69
BWG3 StarTech.com 50 Pkg M6 Mounting Screws In Stock £16.56
BWG3 StarTech.com 100 Pkg M6 Cage Nuts In Stock £27.01
BWG3 StarTech.com 100 Pkg M6 Cage Nuts In Stock £27.11
BWG3 Startech.com 100 Pkg M6 Mounting Screws In Stock £26.84
BWG3 StarTech.com 19in Cable Management Panel In Stock £24.18
BWG3 StarTech.com M6 Rack Screws and Cage Nuts In Stock £15.08
BWG3 StarTech.com Vented 1U Rack Shelf - 10in In Stock £21.05
BWG3 StarTech.com 2 Post Server Rack Shelf - Center Mount - Black In Stock £58.70
BWG3 StarTech.com M6 Mounting Screws 50Pack In Stock £16.56
