Store your lightweight, rack-mountable equipment in this 2-post rack. This 2-post desktop rack provides 8U of storage space for mounting smaller A/V and IT equipment.
With this 2-post rack, you can mount equipment at a fraction of the cost of conventional racks. The lightweight rack is engineered to meet EIA-310 rack-mount standards and is constructed of solid steel, ensuring a sturdy and safe mounting solution for your mission-critical equipment.
The rack features an open frame, free standing design that saves space with a small footprint. It gives you the ability to place rack-mount equipment on any surface in your office, such as your desk. This makes it easy to access your equipment on a daily basis.
The 2-post rack is easy to assemble and includes a pack of 20 M5 screws and cage nuts.
If you're looking for a desktop mounting solution with more rack units, StarTech.com also offers a 12U 2-post desktop rack.
- StarTech.com 8U Open Frame Network Rack - 19" 2 Post Free Standing Desktop Rack for Computer, AV, Media, IT, Data & Server Room Equipment (RK8OD) - rack - 8U
- Product Type
- Rack
- Rack Type
- Open frame - 2-post
- Package Content
- 20 M5 screws, 4 rubber feet, 8 screws, right bracket, left bracket, left vertical rail, right vertical rail, front base bracket, 20 M5 cage nuts
- Height (Rack Units)
- 8U
- Limited lifetime warranty
- Product Type
- Rack
- Rack Type
- Open frame
- Rack Post Qty
- 2-post
- Package Content
- 8U
- Weight Limit
- 50 kg
- Limited warranty: - lifetime
StarTech.com 12U 19in Desktop Open Frame 2 Post Rack | In Stock | £41.63 |
StarTech.com Adjustable Rackmount DIN Rail Kit with Top Hat/Mini/G Rails | In Stock | £79.58 |
StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets | In Stock | £12.20 |
StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £30.66 |
StarTech.com Black Standard Universal Server Rack Cabinet Shelf | In Stock | £30.71 |
StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £28.24 |
StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £54.39 |
StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £57.53 |
StarTech.com 1U 7in Depth Universal Fixed Rack Mount Shelf – 33lbs / 15kg | In Stock | £25.30 |
StarTech.com 8 Port 1U Rackmount USB KVM Switch with OSD | In Stock | £280.59 |
StarTech.com 8 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables | In Stock | £317.20 |
StarTech.com 8 Port 1U Rackmount DVI USB KVM Switch | In Stock | £618.82 |
StarTech.com 24 Port 0.5U Cat5e Patch Panel - RJ45 Ethernet Rackmount Cat 5e 110 Patch Panel | In Stock | £17.22 |
StarTech.com 2U 22in Depth Fixed Rack Mount Shelf - 50lbs / 22kg | In Stock | £56.70 |
StarTech.com 2U 22in Vented Rack Mount Shelf – Fixed Server Rack Cabinet Shelf - 50lbs / 22kg | In Stock | £44.28 |
StarTech.com 2U 16in Universal Vented Rack Mount Cantilever Shelf - Fixed Rack Shelf - 50lbs / 22kg | In Stock | £37.00 |
StarTech.com 2U Rack Mount Cantilever Shelf - Heavy Duty Fixed Server Rack Shelf - 125lbs / 56kg | In Stock | £51.38 |
StarTech.com 1U Brush Strip Horizontal Server Rack Cable Management Panel | In Stock | £38.59 |
StarTech.com 24 Port 1U Rackmount Cat 6 110 Patch Panel | In Stock | £47.16 |
StarTech.com 1U Horizontal Finger Duct Rack Cable Management Panel with Cover | In Stock | £17.75 |
StarTech.com 100 Pkg M6 Screws & Cage Nuts | In Stock | £56.58 |
StarTech.com 50 Pkg M6 Screws & Cage Nuts | In Stock | £30.63 |
StarTech.com 50 Pkg M6 Cage Nuts | In Stock | £20.19 |
StarTech.com 100 Pkg M5 Cage Nuts | In Stock | £9.55 |
StarTech.com 50 Pkg M5 Cage Nuts | In Stock | £5.39 |
StarTech.com 100 Pkg M5 Screws & Cage Nuts | In Stock | £53.55 |
StarTech.com 50 Pkg M5 Screws & Cage Nuts | In Stock | £28.25 |
StarTech.com 50 Pkg M5 Mounting Screws | In Stock | £15.86 |
StarTech.com 100 Pkg M5 Mounting Screws | In Stock | £29.69 |
StarTech.com 50 Pkg M6 Mounting Screws | In Stock | £16.56 |
StarTech.com 100 Pkg M6 Cage Nuts | In Stock | £27.01 |
StarTech.com 100 Pkg M6 Cage Nuts | In Stock | £27.11 |
StarTech.com 22U 36" Knock-Down Server Rack Cabinet with Casters | In Stock | £514.25 |
StarTech.com 19in Cable Management Panel | In Stock | £24.18 |
StarTech.com 4U Open Frame Desktop Rack - 2-Post - Weight Cap. 66 lbs | In Stock | £26.77 |
StarTech.com M6 Mounting Screws 50Pack | In Stock | £16.56 |
