StarTech.com 2-Post Desktop Rack - 8U
Quicklinx: CMCWWS00 Mfr#: RK8OD
£34.28 ex VAT
£41.13 inc VAT
Store your lightweight, rack-mountable equipment in this 2-post rack. This 2-post desktop rack provides 8U of storage space for mounting smaller A/V and IT equipment.
With this 2-post rack, you can mount equipment at a fraction of the cost of conventional racks. The lightweight rack is engineered to meet EIA-310 rack-mount standards and is constructed of solid steel, ensuring a sturdy and safe mounting solution for your mission-critical equipment.
The rack features an open frame, free standing design that saves space with a small footprint. It gives you the ability to place rack-mount equipment on any surface in your office, such as your desk. This makes it easy to access your equipment on a daily basis.
The 2-post rack is easy to assemble and includes a pack of 20 M5 screws and cage nuts.
If you're looking for a desktop mounting solution with more rack units, StarTech.com also offers a 12U 2-post desktop rack.
StarTech.com 8U Open Frame Network Rack - 19" 2 Post Free Standing Desktop Rack for Computer, AV, Media, IT, Data & Server Room Equipment (RK8OD) - rack - 8U
Rack
Rack Type
Open frame - 2-post
Package Content
20 M5 screws, 4 rubber feet, 8 screws, right bracket, left bracket, left vertical rail, right vertical rail, front base bracket, 20 M5 cage nuts
Height (Rack Units)
8U
Rack
Rack Type
Open frame
Rack Post Qty
2-post
Package Content
Height (Rack Units)
8U
Weight Limit
50 kg
Limited warranty: - lifetime
CMCW StarTech.com 12U 19in Desktop Open Frame 2 Post Rack In Stock £40.61
CMCW StarTech.com Adjustable Rackmount DIN Rail Kit with Top Hat/Mini/G Rails In Stock £76.96
CMCW StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets In Stock £11.90
CMCW StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £29.91
CMCW StarTech.com Black Standard Universal Server Rack Cabinet Shelf In Stock £30.44
CMCW StarTech.com 8 Port Rackmount USB VGA KVM Switch w/ Audio (Audio Cables Included) In Stock £335.92
CMCW StarTech.com 50 Pkg M6 Cage Nuts for Server Rack Cabinet In Stock £14.39
CMCW StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £27.99
CMCW StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £52.23
CMCW StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £55.25
CMCW StarTech.com 1U 7in Depth Universal Fixed Rack Mount Shelf – 33lbs / 15kg In Stock £25.06
CMCW StarTech.com 8 Port 1U Rackmount USB KVM Switch with OSD In Stock £278.07
CMCW StarTech.com 8 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables In Stock £309.46
CMCW StarTech.com 8 Port 1U Rackmount DVI USB KVM Switch In Stock £600.89
CMCW StarTech.com 24 Port 0.5U Cat5e Patch Panel - RJ45 Ethernet Rackmount Cat 5e 110 Patch Panel In Stock £31.67
CMCW StarTech.com 2U 22in Depth Fixed Rack Mount Shelf - 50lbs / 22kg In Stock £55.31
CMCW StarTech.com 2U 22in Vented Rack Mount Shelf – Fixed Server Rack Cabinet Shelf - 50lbs / 22kg In Stock £43.20
CMCW StarTech.com 2U 16in Universal Vented Rack Mount Cantilever Shelf - Fixed Rack Shelf - 50lbs / 22kg In Stock £36.09
CMCW StarTech.com 2U Rack Mount Cantilever Shelf - Heavy Duty Fixed Server Rack Shelf - 125lbs / 56kg In Stock £50.11
CMCW StarTech.com 1U Brush Strip Horizontal Server Rack Cable Management Panel In Stock £38.24
CMCW StarTech.com 24 Port 1U Rackmount Cat 6 110 Patch Panel In Stock £46.00
CMCW StarTech.com 1U Horizontal Finger Duct Rack Cable Management Panel with Cover In Stock £17.41
CMCW StarTech.com 100 Pkg M6 Screws & Cage Nuts In Stock £55.20
CMCW StarTech.com 50 Pkg M6 Screws & Cage Nuts In Stock £29.89
CMCW StarTech.com 100 Pkg M5 Cage Nuts In Stock £25.96
CMCW StarTech.com 50 Pkg M6 Cage Nuts In Stock £19.69
CMCW StarTech.com 100 Pkg M5 Cage Nuts In Stock £29.98
CMCW StarTech.com 50 Pkg M5 Cage Nuts In Stock £15.03
CMCW StarTech.com 100 Pkg M5 Screws & Cage Nuts In Stock £52.24
CMCW StarTech.com 50 Pkg M5 Screws & Cage Nuts In Stock £27.56
CMCW StarTech.com 50 Pkg M5 Mounting Screws In Stock £15.48
CMCW StarTech.com 100 Pkg M5 Mounting Screws In Stock £28.96
CMCW StarTech.com 50 Pkg M6 Mounting Screws In Stock £16.16
CMCW StarTech.com 100 Pkg M6 Cage Nuts In Stock £26.90
CMCW StarTech.com 100 Pkg M6 Cage Nuts In Stock £27.56
CMCW StarTech.com 22U 36" Knock-Down Server Rack Cabinet with Casters In Stock £501.70
CMCW StarTech.com 19in Cable Management Panel In Stock £23.58
CMCW StarTech.com 4U Open Frame Desktop Rack - 2-Post - Weight Cap. 66 lbs In Stock £26.53
CMCW StarTech.com M6 Mounting Screws 50Pack In Stock £16.79
