StarTech.com 2-Post Desktop Rack - 8U
Quicklinx: CMCWWS00 Mfr#: RK8OD
Hurry, only 3 left in stock!
£35.14 ex VAT
£42.16 inc VAT
Store your lightweight, rack-mountable equipment in this 2-post rack. This 2-post desktop rack provides 8U of storage space for mounting smaller A/V and IT equipment.
With this 2-post rack, you can mount equipment at a fraction of the cost of conventional racks. The lightweight rack is engineered to meet EIA-310 rack-mount standards and is constructed of solid steel, ensuring a sturdy and safe mounting solution for your mission-critical equipment.
The rack features an open frame, free standing design that saves space with a small footprint. It gives you the ability to place rack-mount equipment on any surface in your office, such as your desk. This makes it easy to access your equipment on a daily basis.
The 2-post rack is easy to assemble and includes a pack of 20 M5 screws and cage nuts.
If you're looking for a desktop mounting solution with more rack units, StarTech.com also offers a 12U 2-post desktop rack.
Startech 8U Open Frame Network Rack - 19" 2 Post Free Standing Desktop Rack for Computer, AV, Media, IT, Data & Server Room Equipment (RK8OD) - rack - 8U
Rack
Rack Type
Open frame - 2-post
Package Content
20 M5 screws, 4 rubber feet, 8 screws, right bracket, left bracket, left vertical rail, right vertical rail, front base bracket, 20 M5 cage nuts
Height (Rack Units)
8U
Rack
Rack Type
Open frame
Rack Post Qty
2-post
Package Content
Height (Rack Units)
8U
Weight Limit
50 kg
Limited warranty: - lifetime
CMCW StarTech.com 12U 19in Desktop Open Frame 2 Post Rack In Stock £41.63
CMCW StarTech.com Adjustable Rackmount DIN Rail Kit with Top Hat/Mini/G Rails In Stock £79.45
CMCW StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets In Stock £12.20
CMCW StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £30.66
CMCW StarTech.com Black Standard Universal Server Rack Cabinet Shelf In Stock £30.71
CMCW StarTech.com 8 Port Rackmount USB VGA KVM Switch w/ Audio (Audio Cables Included) In Stock £351.41
CMCW StarTech.com 50 Pkg M6 Cage Nuts for Server Rack Cabinet In Stock £14.44
CMCW StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £28.24
CMCW StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £54.39
CMCW StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £57.53
CMCW StarTech.com 1U 7in Depth Universal Fixed Rack Mount Shelf – 33lbs / 15kg In Stock £25.33
CMCW StarTech.com 8 Port 1U Rackmount USB KVM Switch with OSD In Stock £280.59
CMCW StarTech.com 8 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables In Stock £317.20
CMCW StarTech.com 8 Port 1U Rackmount DVI USB KVM Switch In Stock £543.36
CMCW StarTech.com 24 Port 0.5U Cat5e Patch Panel - RJ45 Ethernet Rackmount Cat 5e 110 Patch Panel In Stock £15.50
CMCW StarTech.com 2U 22in Depth Fixed Rack Mount Shelf - 50lbs / 22kg In Stock £56.70
CMCW StarTech.com 2U 22in Vented Rack Mount Shelf – Fixed Server Rack Cabinet Shelf - 50lbs / 22kg In Stock £44.28
CMCW StarTech.com 2U 16in Universal Vented Rack Mount Cantilever Shelf - Fixed Rack Shelf - 50lbs / 22kg In Stock £37.00
CMCW StarTech.com 2U Rack Mount Cantilever Shelf - Heavy Duty Fixed Server Rack Shelf - 125lbs / 56kg In Stock £51.38
CMCW StarTech.com 1U Brush Strip Horizontal Server Rack Cable Management Panel In Stock £38.59
CMCW StarTech.com 24 Port 1U Rackmount Cat 6 110 Patch Panel In Stock £47.16
CMCW StarTech.com 1U Horizontal Finger Duct Rack Cable Management Panel with Cover In Stock £17.48
CMCW StarTech.com 100 Pkg M6 Screws & Cage Nuts In Stock £56.58
CMCW StarTech.com 50 Pkg M6 Screws & Cage Nuts In Stock £30.63
CMCW StarTech.com 50 Pkg M6 Cage Nuts In Stock £20.19
CMCW StarTech.com 100 Pkg M5 Cage Nuts In Stock £30.81
CMCW StarTech.com 50 Pkg M5 Screws & Cage Nuts In Stock £28.25
CMCW StarTech.com 100 Pkg M5 Mounting Screws In Stock £29.69
CMCW StarTech.com 50 Pkg M6 Mounting Screws In Stock £16.56
CMCW StarTech.com 100 Pkg M6 Cage Nuts In Stock £27.01
CMCW StarTech.com 100 Pkg M6 Cage Nuts In Stock £27.11
CMCW StarTech.com 22U 36" Knock-Down Server Rack Cabinet with Casters In Stock £514.25
CMCW Startech.com 100 Pkg M6 Mounting Screws In Stock £26.84
CMCW StarTech.com 19in Cable Management Panel In Stock £24.18
CMCW StarTech.com 4U Open Frame Desktop Rack - 2-Post - Weight Cap. 66 lbs In Stock £26.77
CMCW StarTech.com M6 Mounting Screws 50Pack In Stock £16.56
