Control, and transfer files between 2 USB connected computers using a single keyboard and mouse. The SVKMS 2 Port USB KM Switch Keyboard Mouse Sharing Cable with File Transfer allows you to control two computer systems using a single keyboard and mouse set, and offers the ability to transfer files.
A compact keyboard mouse switch solution that connects your two systems using a standard USB 2.0 port, and installs automatically without requiring additional software or drivers. Once installed, switching between systems is as simple as moving the mouse over to your second display, or using hot-keys.
This simple KM link cable also provides the added benefits of clipboard sharing so you can copy and paste text from one system to another, and drag and drop files for effortless transfers and data management.
- StarTech.com 2 Port USB KM Switch - USB Keyboard and Mouse Switch with File Transfer - keyboard/mouse switch - 2 ports
- Keyboard/mouse switch - 2 ports
- Subtype
- USB
- 2 cm x 12 cm x 1 cm
- 45 g
- System Requirements
- Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Windows 8 (32/64 bits)
- 2-year warranty
- Enclosure Type
- Desktop
- Subtype
- USB
- Keyboard / Mouse Interface
- PS/2, USB
- 2 x USB Type A , 1 x keyboard (USB) Type A , 1 x mouse (PS/2)
- OS Required
- 2 cm
- 12 cm
- 1 cm
- 45 g
- Limited warranty - 2 years
