StarTech.com 2-Port USB-C MST Hub, 4K 60Hz
Quicklinx: H2Z1WS00 Mfr#: MST14CD122DP
Device Type: Laptop
Type: Display Adaptor
Device Screen Size: [N/A]
Colour: Space grey
£46.21 ex VAT
£55.45 inc VAT
This USB-C to DisplayPort MST Hub enables a connection to two DisplayPort monitors, using a DisplayPort Alternate Mode (DP Alt Mode) capable USB-C host device.
  • 4K at 60Hz with HDR
    Multi-Stream Transport (MST) technology combines multiple video signals into a single output signal/stream. This MST Hub separates the single input stream into two independent signals, one for each DisplayPort-enabled display. Support for High Dynamic Range (HDR) offers increased contrast, brightness, colors, and luminosity.
  • Multitasking Made Easy
    Configure the dual-DP displays in extended or mirrored mode. Create a high-performance workstation by adding two independent 4K 60Hz displays. This empowers increased multi-tasking across your organization, resulting in increased productivity.
  • Hassle-Free Setup
    Windows devices supporting DP Alt Mode over USB-C feature native support for MST. This USB-C to DP hub is compatible Thunderbolt 3/4 and USB4-enabled Windows devices with 11th generation (and later) processors. Plug-and-play installation, with no drivers or software required. The 12in (30cm) built-on cable provides options for flexible installation configurations, reducing the amount of strain on ports and connectors. Additionally, this dual-monitor splitter is bus-powered, requiring no external power source. This product is backed for 3 years, including free lifetime 24/5 multilingual technical assistance.
StarTech.com 2-Port USB-C MST Hub, USB Type-C to 2x DisplayPort Multi-Monitor Adapter for Laptop, Dual-DP up to 4K 60Hz w/ DP 1.4 Alt Mode & DSC, HDR, 1ft (30cm) Cable, USB Bus-Powered - Multi-Stream Transport Hub (MST14CD122DP) - video/audio splitter - 2 ports
Video/audio splitter - 2 ports
Subtype
DisplayPort
Ports
2 x DisplayPort
MST support, DisplayPort Alternate mode, DSC, plastic housing, USB powered, HDR support, dual display support, 2.1 channel audio support
14.2 cm x 17 cm x 3 cm
108.8 g
Space grey
Microsoft Windows 10 / 11
3-year warranty
Enclosure Type
Desktop
Subtype
DisplayPort
Ports
2 x DisplayPort
Max Resolution
4K @ 60 Hz
2 x DisplayPort
Space grey
1 x USB-C cable - 30 cm
DisplayPort 1.4, DisplayPort 1.2, RoHS, WEEE, RCM, HDCP 2.2, DSC, Thunderbolt 3, Thunderbolt 4, Plug and Play
14.2 cm
17 cm
3 cm
108.8 g
Limited warranty - 3 years , Technical support - assistance - lifetime
5 - 90% RH (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
H2Z1 StarTech.com 1m 3.3ft DisplayPort 1.4 Cable In Stock £6.91
H2Z1 StarTech.com 2m 6.6ft DisplayPort 1.4 Cable In Stock £8.49
H2Z1 StarTech.com 3ft DisplayPort 1.4 8K 60Hz In Stock £13.82
H2Z1 StarTech.com 6ft DisplayPort 1.4 8K 60Hz In Stock £14.98
H2Z1 StarTech.com 10ft DisplayPort 1.4 8K 60Hz In Stock £20.57
H2Z1 StarTech.com 13ft DisplayPort 1.4 8K 60Hz In Stock £29.12
H2Z1 StarTech.com 16ft DisplayPort 1.4 8K 60Hz In Stock £35.05
Device Type: Laptop
Colour: Space grey
