StarTech.com 3ft DisplayPort 1.4 8K 60Hz
Quicklinx: GJJQWS00 Mfr#: DP14VMM1M
Length: 1m
18 In Stock
£14.08 ex VAT
£16.89 inc VAT
VESA Certified DisplayPort 1.4 Cable - 8K 60Hz HDR10 - 3.3 ft. (1 m).
  • 8K: enabling business continuity
    8K has a resolution of 7680 x 4320 and is also known as 4320p and Ultra High Definition (UHD). Suitable for digital signage and other commercial displays that require the highest available resolution. This cable is backward compatible with 4K and 5K displays making it the perfect peripheral to start future proofing your cabling infrastructure.
  • Comprehensive?product testing?and?expert?technical support
    StarTech.com?conducts thorough?compatibility and performance?testing?on?all?the products?to?ensure they are meeting or?exceeding industry standards?and providing?high-quality products to the customers. Their?local?StarTech.com?Technical?Advisors?have a broad product expertise?and?work directly with StarTech.com?Engineers to?provide support for the customers?both pre- and post-sales.
StarTech 3ft (1m) VESA Certified DisplayPort 1.4 Cable, 8K 60Hz HDR10, Ultra HD 4K 120Hz DP Video Cable, DisplayPort to DisplayPort Cable, DP Cord for Monitors/Displays, M/M - DP 1.4 Cable with Latches (DP14VMM1M) - DisplayPort cable - DisplayPort to DisplayPort - 1 m
DisplayPort cable
Shielded
Molded, passive cable, 8K60Hz (7680 x 4320) support, 4K120Hz (3840 x 2160) support, strain relief, HBR3 support, Display Stream Compression 1.2 (DSC), DisplayPort Multi-Stream Transport (MST), 32 audio channels, HDR10 support, 7.1 audio channel support, Chroma subsampling (4:4:4), 32.4 Gbps data rate, Forward Error Correction, 5.1 audio channel support
Cable Length
1 m
Connector
20 pin DisplayPort - male
Connector (Second End)
DisplayPort 1.4
Grey, black
DisplayPort cable
Shielded
Shielding Material
Jacket Material
Thermoplastic elastomer (TPE)
American Wire Gauge (AWG)
34
Plated Connector
Gold
Cable Length
1 m
Outside Diameter
4.5 mm
Grey, black
Connector
DisplayPort 1.4, RoHS, HDCP 2.2, 8K VESA certified
Shipping Width
22 cm
Shipping Depth
20 cm
Shipping Height
2 cm
Shipping Weight
59 g
GJJQ StarTech.com VESA-Certified DP 2.1 Cable In Stock £14.37
GJJQ StarTech.com VESA-Certified DP 2.1 Cable In Stock £14.40
GJJQ StarTech.com VESA-Certified DP 2.1 Cable In Stock £20.37
Length: 1m
