StarTech.com 2 Port USB C Card - 2x C
Quicklinx: D28KWS00 Mfr#: PEXUSB312C2
Add two 10Gbps USB Type-C ports to your computer, through a PCI Express slot. This USB 3.1 card lets you add two USB-C ports to your computer, through a PCI Express slot. It enables you to upgrade your current system by adding two USB 3.1 Gen 2 ports to your computer and giving you access to data transfer speeds up to 10Gbps.
With the addition of two USB Type-C ports, you can rest assured your computer is compatible with the growing popularity of USB-C peripherals.
By adding 10Gbps USB ports to your computer, you can harness the speed of USB 3.1 Gen 2 and rest assured you're ready for both current and future high-bandwidth USB-C devices.
With higher data throughput support, this USB 3.1 PCIe card is a necessity for external drives, drive enclosures, and many other USB 3.1 peripherals. Plus, the USB card includes an optional SATA power connector to connect to your system power supply and deliver up to 900mA of power per port to USB 3.1 bus-powered devices (500mA for USB 2.0). The card is ideal for use with large external storage solutions.
The card is backward compatible with USB 3.0 (5Gbps) and USB 2.0 (480mbps) devices. You can add the card now for use with newer USB-C devices, while still connecting your existing USB peripherals using a variety of USB-C cables and adapters.
The USB 3.1 card is compatible with a broad range of Windows and Linux operating systems. Plus, the high-quality card includes both standard-profile and low-profile brackets, making it easy to install in full or small form-factor PCs and servers.
StarTech.com Replaced by PEXUSB312A3 - 2-Port USB PCIe Card - 10Gbps USB 3.1 Gen 2 Type-A PCI Express Host Controller Expansion Card (PEXUSB312C2) - USB adapter - PCIe 3.0 x4 - USB-C 3.1 Gen 2 x 2
USB adapter
Plug-in card - low profile
Interface (Bus) Type
PCI Express 3.0 x4
Ports
USB-C 3.1 Gen 2 x 2
USB 3.1
Data Transfer Rate
10 Gbps
USB 1.1, USB 2.0, USB 3.0, USB 3.1 Gen 2
Microsoft Windows Server 2012, Apple OS X 10.9 Mavericks, Apple MacOS X 10.10, Microsoft Windows 7 / 8 / 8.1 / 10 (32/64 bits), Linux 3.5 to 4.4.x LTS versions
P/N: HB31C2A1CGB, HB31C2A1CGS, HB31C2A2CB, HB31C3A1CB, HB31C3A1CPD3, HB31C3A1CS, HB31C3ASDMB, HB31C4AS, ICUSBCPLLD25, S251BRU31C3, SDOCK4U313, USB3C2ESAT3
USB adapter
PCI Express 3.0 x4
Ports
USB-C 3.1 Gen 2 x 2
Wired
USB 3.1
Data Transfer Rate
10 Gbps
2 x USB 3.1 Gen 2 - 24 pin USB-C , 1 x SATA power - 15 pin Serial ATA power (internal)
Low-profile bracket
D28K StarTech.com 6in 4 Pin Molex to SATA Power Cable Adapter In Stock £5.06
D28K StarTech.com 7 Port PCIe USB 3.0 Card In Stock £56.73
D28K StarTech.com 3 Port PCIe USB 3.0 Card + GbE In Stock £42.00
D28K StarTech.com USB 3.1 USB-C to USB-A Adapter In Stock £8.87
D28K StarTech.com 1m USB 3.1 USB-C to USB-A Cbl In Stock £7.48
D28K StarTech.com 1m USB 3.1 C to Micro-B Cable In Stock £10.24
D28K StarTech.com 1m 3ft USB 3.1 USB-C Cable M/M In Stock £12.99
D28K StarTech.com 1m 3ft USB 3.1 C to B Cable In Stock £14.97
