Connect your USB Type-C device to a USB Type-A device, with this durable adapter. Have you purchased a new device that only came equipped with a USB Type-C or Thunderbolt 3 port, such as a laptop or tablet? Do you need to connect to older USB 3.0 or 2.0 devices?
This USB-C to USB-A adapter makes it easy to connect USB 3.0 and 2.0 devices to new USB-C devices. Simply plug the adapter into the USB Type-C port to turn it into a USB Type-A port, and you're ready to connect your older devices. The adapter is compatible with USB 3.0 enabled computers, such as the Dell Latitude 11 5000 2-in-1, and more.
USB 3.0 is also known as USB 3.1 Gen 1 (5Gbps).
Provide superior connections with a USB-IF certified adapter
The adapter has undergone rigorous compliance testing and is certified by USB-IF (USB Implementers Forum) to meet all USB 3.2 Gen 1 specifications. This includes all environmental, electrical and mechanical standards, which ensures a reliable, high-quality connection for all of your USB-C devices. The USB31CAADP is backed by StarTech.com's 2-year warranty for guaranteed reliability. Note : USB 3.2 Gen 1 is also known as USB 3.0 (5Gbps).
- StarTech.com USB-C to USB Adapter - 6in - USB-IF Certified - USB-C to USB-A - USB 3.1 Gen 1 - USB C Adapter - USB Type C (USB31CAADP) - USB-C adapter - 24 pin USB-C to USB Type A - 15.2 cm
- USB-C adapter
- Technology
- Double shielded
- Length
- 15.2 cm
- Connector
- 24 pin USB-C - male
- Connector (Second End)
- 9 pin USB Type A - female
- USB 3.0
- Black
- Works With Chromebook
- 2-year warranty
- Designed For
- P/N: BNDDKT30CAHV, DK30C2DPEP, DK30C2DPEPUE, DK30C2DPPD, DK30C2DPPDUE, DK31C3HDPD, DK31C3HDPDUE, DKM30CHDPD, DKM30CHDPDUE, HB30A3A1CST, HB31C2A1CGB, HB31C2A1CGS, HB31C2A2CB, HB31C3A1CB, HB31C3A1CPD3, HB31C3A1CS, HB31C3ASDMB, HB31C4AS, PEXUSB311AC3, PEXUSB312A1C1H, PEXUSB312A2C2V, TB33A1C, USBA2DPGB
- USB-C adapter
- Technology
- Double shielded
- Plated Connector
- Nickel
- Length
- 15.2 cm
- Black
- Connector
- USB 3.0, RoHS, USB-IF
- 2-year warranty
- Designed For
- P/N: ARMTBLTDT, ARMTBLTIW, ARMTBLTUGN, BNDDKT30CAHV, DK30C2DPEP, DK30C2DPEPUE, DK30C2DPPD, DK30C2DPPDUE, DK31C3HDPD, DK31C3HDPDUE, DKM30CHDPD, DKM30CHDPDUE, HB30A3A1CFB, HB30A3A1CSFS, HB30A3A1CST, HB30C3A1CFB, HB30C3A1CFS, HB31C2A1CGB, HB31C2A1CGS, HB31C2A2CB, HB31C3A1CB, HB31C3A1CPD3, HB31C3A1CS, HB31C3ASDMB, HB31C4AS, PEXUSB311AC2, PEXUSB311AC3, PEXUSB312A1C1H, PEXUSB312A2C2V, PEXUSB312C2, PEXUSB312EIC, SECTBLTPOS, ST3300G3UA, ST43004UA, ST4300MINI, ST73007UA, STNDTBLT1A5T, STNDTBLT1FS, TB33A1C, USB31GEHD, USB31GEVG, USB3DDOCKFT, USB3DOCKH2DP, USB3DOCKHDPC, USB3SDOCKD, USB3SDOCKDD, USB3SDOCKHD, USB3SDOCKHDV, USB3SMDOCK4K, USB3SMDOCKHV, USB3VDOCK4DP, USB3VDOCKD, USBA2DPGB
StarTech.com 1m USB 2.0 C to Micro-USB Cable | In Stock | £7.99 |
StarTech.com USB 3.1 USB-C to USB-A Adapter | In Stock | £10.07 |
StarTech.com 1m USB 3.1 USB-C to USB-A Cbl | In Stock | £10.18 |
StarTech.com 1m USB 3.1 C to Micro-B Cable | In Stock | £11.06 |
StarTech.com 1m 3ft USB 3.1 USB-C Cable M/M | In Stock | £14.29 |
StarTech.com 1m USB 2.0 USB-C to USB-A Cable | In Stock | £9.09 |
StarTech.com 1m USB 2.0 USB-C to USB-B Cable | In Stock | £10.11 |
StarTech.com USB-C Cable - M/M - 1m (3ft.) - USB 2.0 | In Stock | £9.47 |
StarTech.com USB 3.0 USB-C to USB-A Adapter | In Stock | £8.05 |
StarTech.com 6ft USB-C to A Cable - USB 2.0 | In Stock | £11.44 |
StarTech.com 1m 3ft USB 3.1 C to B Cable | In Stock | £16.96 |
