This 2 Port USB A Female Slot Plate converts the USB pins from most AT style Pentium (and newer) motherboards to 2 standard USB A-Style ports. The plate can be mounted on the rear panel of a computer case, adding two USB A female ports for simple connection to USB peripheral devices.
- StarTech.com 2 Port USB A Female Slot Plate Adapter - USB panel - USB (F) to 5 pin in-line (F) - USBPLATE - USB panel - USB to 5 pin in-line
- USB panel
- Connector
- 2 x 4 pin USB Type A - female
- Connector (Second End)
- 2 x 5 pin in-line - female
- Limited lifetime warranty
- USB panel
- Connector
StarTech.com 2 Port USB 3.0 A Female Slot Plate Adapter | In Stock | £22.28 |
StarTech.com 4 Port USB A Female Slot Plate Adapter | In Stock | £8.14 |
