Add two USB 3.0 ports through a Mini PCI Express slot. The MPEXUSB3S22B 2-Port Mini PCI Express USB 3.0 Card with Bracket Kit adds two external USB 3.0 ports to small form-factor systems, for connecting a variety of different peripherals. The card also includes optional standard and low profile brackets to fit a rear expansion bay if needed.
The Mini PCIe USB 3.0 card supports the full SuperSpeed USB specification, with fast data transfer speeds (up to 5Gbps), as well as 900mA of power per port, making it a convenient addition for connecting your USB 3.0 peripheral devices.
Enhanced with UASP support (USB Attached SCSI Protocol), this USB 3.0 controller performs up to 70% faster than conventional USB 3.0 when paired with a UASP supported enclosure (Note: UASP requires a compatible operating system). Using a more efficient protocol than the traditional USB BOT (Bulk-Only Transport), UASP technology optimizes transfers by allowing multiple commands to be processed simultaneously, significantly increasing transfer speeds for less wait time on data transfers.
Using the Mini PCI Express (Mini Card) form factor and offering compliance with PCI Express Gen 2, this adapter card is designed for use in the latest small form factor computer systems, such as Mini-ITX or custom embedded solutions where a standard PCIe card would not fit.
UASP is supported in Windows 8, Server 2012 and Linux kernel 2.6.3 or later. In testing UASP performed with up to a 70% faster read / 40% faster write speed over traditional USB 3.0 at peak performance.
At the same peak in testing, UASP also showed up to an 80% reduction in required processor resources.
Test results were obtained using an Intel Ivy Bridge system, StarTech.com add-on USB 3.0 cards, a UASP-enabled StarTech.com enclosure, and a SATA III solid state drive.
Improved Performance with UASP
UASP is supported in Windows 8, Server 2012 and Linux kernel 2.6.3 or later. In testing UASP performed with up to a 70% faster read / 40% faster write speed over traditional USB 3.2 Gen 1 at peak performance. At the same peak in testing, UASP also showed up to an 80% reduction in required processor resources. Test results were obtained using an Intel Ivy Bridge system, StarTech.com add-on USB 3.2 Gen 1 cards, a UASP-enabled StarTech.com enclosure, and a SATA III solid state drive.
- StarTech.com 2 Port SuperSpeed Mini PCI Express USB 3.0 Adapter Card w/ Bracket Kit and UASP Support - Dual Port Mini PCIe USB 3 Card (MPEXUSB3S22B) - USB adapter - PCIe Mini Card - USB 3.0 x 2
- USB adapter
- Form Factor
- Plug-in card - low profile
- Interface (Bus) Type
- PCI Express Mini Card
- PCI Specification Revision
- PCIe 2.0
- Ports
- USB 3.0 x 2
- 3 cm x 51 cm
- 150 g
- Data Link Protocol
- USB, USB 2.0, USB 3.0
- Data Transfer Rate
- 5 Gbps
- USB 1.1, USB 2.0, USB 3.0
- System Requirements
- Linux, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits)
- 2-year warranty
- Designed For
- P/N: S3510BMU33, S3510SMU33, SATDOCK2REU3, SDOCK2ERU33, SDOCK2U313R, SDOCK2U33, SDOCK2U33EB, SDOCK2U33RE, SDOCK2U33V, SDOCK4U33, SDOCKU33BV, SDOCKU33EBV, USB3S2SAT3CB
- USB adapter
- Form Factor
- PCIe 2.0
- Ports
- USB 3.0 x 2
- Connectivity Technology
- Wired
- USB, USB 2.0, SuperSpeed USB 3.0
- 5 Gbps
- 2 x USB 3.0 - 9 pin USB Type A
- Compatible Slots
- 1 x PCI Express Mini Card
- Included Accessories
- Low-profile bracket, full-height bracket
- Cables Included
- 1 x USB cable - 54.6 cm
- FCC, RoHS
- Software Included
- Drivers & Utilities
- OS Required
- 3 cm
- 51 cm
- 150 g
- Limited warranty - 2 years
- 0 °C
- 55 °C
- 5 - 95%
- Designed For
StarTech.com 4 Port PCI Express PCIe SuperSpeed USB 3.0 Controller Card Adapter with UASP | In Stock | £34.48 |
StarTech.com 4 Port PCIe USB 3.0 Card | In Stock | £24.93 |
