Add 2 SuperSpeed USB 3.0 ports to a computer through a PCI slot. The PCIUSB3S22 2-Port PCI to USB 3.0 Card enables you to connect USB 3.0 peripherals to a PC through a legacy PCI host bus, which doubles the data transfer speeds when used with USB 3.0 peripherals than would be possible with a USB 2.0 host connection - up to 1.3 Gbps (PCI bus limit).
The card features an optional SATA power connection, which enables each port to supply up to 900mA of power to USB 3.0 bus-powered devices.
By supporting a legacy (PCI) host connection, the card adds updated peripheral connectivity, without having to upgrade to a PCIe-equipped motherboard or rely on the backward compatibility of USB 3.0 peripherals.
- StarTech.com 2 Port PCI SuperSpeed USB 3.0 Adapter Card with SATA Power - Dual Port PCI USB 3 Controller Card (PCIUSB3S22) - USB adapter - PCI-X - USB 3.0 x 2
- USB adapter
- Form Factor
- Plug-in card - low profile
- Interface (Bus) Type
- PCI-X
- Bus Voltage
- Universal (3.3 V & 5.0 V)
- Ports
- USB 3.0 x 2
- 1 cm x 12.3 cm x 5.6 cm
- 60 g
- Data Link Protocol
- USB, USB 2.0, USB 3.0
- Data Transfer Rate
- 5 Gbps
- Processor
- NEC uPD720202
- USB 1.1, USB 2.0, USB 3.0
- Red
- System Requirements
- Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits)
- Limited lifetime warranty
- Designed For
- P/N: S3510BMU33, S3510SMU33, ST7300USB3B, UNI251BMU33
- USB adapter
- Form Factor
- PCI-X
- Bus Voltage
- Ports
- USB 3.0 x 2
- Connectivity Technology
- Wired
- USB, USB 2.0, SuperSpeed USB 3.0
- 5 Gbps
Processor / Memory
- Processor
- NEC uPD720202
- 2 x USB 3.0 - 9 pin USB Type A
- Compatible Slots
- 1 x PCI-X
- Included Accessories
- Low-profile bracket
- FCC, RoHS
- Red
- Software Included
- Drivers & Utilities
- OS Required
- 1 cm
- 12.3 cm
- 5.6 cm
- 60 g
- Limited warranty - lifetime
- 5 °C
- 50 °C
- 15 - 90%
- Designed For
StarTech.com 7 Port PCI USB Card Adapter | In Stock | £16.36 |
