StarTech.com 4 Port PCI SuperSpeed USB 3.0 Adapter Card with SATA / SP4 Power
Quicklinx: 8HMXWS00 Mfr#: PCIUSB3S4
Type: USB adapter
Compatibility: PC
Interface: PCI-X
  • Windows 8 (32/64 bits)
£54.71 ex VAT
£65.65 inc VAT
Add 4 SuperSpeed USB 3.0 ports to a computer through a PCI slot. The PCIUSB3S4 4-Port PCI to USB 3.0 Card enables legacy PCI slots to support the SuperSpeed USB 3.0 standard, which is capable of data transfer rates up to 5 Gbps. Using USB 3.0 devices with this card will increase data transfer rates with up to 1.3 Gbps of available bandwidth (PCI bus limit) - more than doubling performance compared to a USB 2.0 connection.
This versatile USB 3.0 adapter includes an optional SATA power connector which allows each USB port to deliver up to 900mA of power to connected USB 3.0 devices - suitable for even the most power hungry devices.
A perfect solution for older PCI-based systems or computers with only PCI expansion slots remaining, the card allows those systems to stay relevant and up-to-date with the latest USB technology. The card is also backward compatible with USB 2.0 and 1.x devices, so it will not only work with any future USB 3.0 devices, but will also support older devices.
StarTech.com 4 Port PCI SuperSpeed USB 3.0 Adapter Card with SATA/SP4 Power - Quad Port PCI USB 3 Controller Card (PCIUSB3S4) - USB adapter - PCI-X - USB 3.0 x 4
USB adapter
Plug-in card - low profile
Interface (Bus) Type
PCI-X
Bus Voltage
Universal (3.3 V & 5.0 V)
Ports
USB 3.0 x 4
2 cm x 13.3 cm x 6.5 cm
80 g
USB, USB 2.0, USB 3.0
Data Transfer Rate
5 Gbps
NEC uPD720202
USB 1.1, USB 2.0, USB 3.0
Red
Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits), Windows 10 (32/64 bits)
P/N: HBS304A24A, S3510BMU33, S3510SMU33, UNI251BMU33, USB221SS
USB adapter
PCI-X
Bus Voltage
Ports
USB 3.0 x 4
Wired
USB, USB 2.0, SuperSpeed USB 3.0
Data Transfer Rate
5 Gbps
Processor / Memory
NEC uPD720202
4 x USB 3.0 - 9 pin USB Type A
Compatible Slots
1 x PCI-X
Low-profile bracket
FCC, RoHS
Red
Software Included
Drivers & Utilities
2 cm
13.3 cm
6.5 cm
80 g
Limited warranty - lifetime
5 °C
50 °C
15 - 90%
8HMX StarTech.com 2 Port PCI Express PCIe SuperSpeed USB 3.0 Controller Card w/ SATA Power In Stock £11.59
8HMX StarTech.com 2 Port PCI Express (PCIe) SuperSpeed USB 3.0 Card Adapter with UASP - LP4 Power In Stock £22.94
Type: USB adapter
Compatibility: PC
Interface: PCI-X
