StarTech.com 2 Port RS232 PCI Express Serial Card w/ Breakout Cable
Quicklinx: 7W8QWS00 Mfr#: PEX2S553B
Add 2 RS-232 serial ports to your standard or small form factor computer through a PCI Express expansion slot. The PEX2S553B 2-Port PCI Express Serial Card w/ Breakout Cable lets you add two RS232 serial ports using a single PCIe expansion slot. With the included break-out cable, you can easily add two ports to a single low profile slot.
The PCIe serial card features a native single-chip design that provides optimum reliability and speed, reducing the CPU load by up to 48% over conventional bridge-chip serial cards - a cost-effective solution for connecting legacy serial devices to PCIe enabled computers.
The multiport PCIe Serial Adapter includes both full and low-profile/half-height brackets for compatibility with standard and small form factor computers, and is compatible with a broad range of operating systems, including Windows 7/Server 2008 R2, 2003/Vista/XP (32 and 64 bit), Linux Kernel 2.6.11 and up, as well as MAC OS 10.5 and above.
This product is a replacement for the PEX2S552B card.
StarTech.com 2 Port RS232 PCI Express Serial Card w/ Breakout Cable - serial adapter - PCIe - RS-232 x 2
Serial adapter
Plug-in card - low profile
Interface (Bus) Type
PCI Express
Ports
RS-232 x 2
8 cm x 8 cm x 2.3 cm
Cabling Type
Serial RS-232
Data Transfer Rate
250 Kbps
MosChip Semiconductor
Linux, Microsoft Windows 95/98 Second Edition, Microsoft Windows XP Embedded, Microsoft Windows CE 5.0, Apple MacOS X 10.4 or later, Microsoft Windows Embedded POSReady 2009, Microsoft Windows Server 2008 R2, Microsoft Windows 2000/XP/Vista/7, Microsoft Windows CE 6.0, Microsoft Windows Server 2003 (32/64-bits)
Serial adapter
PCI Express
Ports
RS-232 x 2
Wired
Cabling Type
Serial RS-232
Data Transfer Rate
250 Kbps
Flow control
Processor / Memory
2 x RS-232 - 9 pin D-Sub (DB-9)
Compatible Slots
1 x PCI Express
WHQL, RoHS
8 cm
8 cm
2.3 cm
Limited warranty - lifetime
70 °C
5 - 85%
7W8Q StarTech.com DB9 to DB25 Serial Cable Adapter - F/M In Stock £5.43
