StarTech.com 2 Port RS232 Mini PCI Express Serial Card with 16950 UART
Quicklinx: 76MZWS00 Mfr#: MPEX2S952
  • Windows 8 (32/64 bits)
Add two RS232 serial ports to an embedded system with a mini PCI-Express slot. The MPEX2S952 2-port mini PCI Express serial card turns a mini-PCIe slot into two RS232 (DB9) serial ports - a cost-saving solution for adding legacy serial support for embedded systems that aren't normally compatible.
The adapter card features a native PCI Express single chip design, which allows you to take advantage of full PCI Express capability by providing improved speed and reliability while reducing the load applied to the CPU by as much as 48% over conventional "bridge chip" serial cards .
The 2-port mini PCI Express RS232 serial card is designed and constructed to provide long-lasting durability and reliability.
StarTech.com 2 Port RS232 Mini PCI Express Serial Card w/ 16950 UART - serial adapter - PCIe Mini Card - RS-232 x 2
Serial adapter
Plug-in module
Interface (Bus) Type
PCI Express Mini Card
Ports
RS-232 x 2
RS-232
Data Transfer Rate
460 Kbps
Green
Microsoft Windows 2000, Microsoft Windows Server 2008 R2, Linux 2.4.x or later, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits)
Serial adapter
Plug-in module
Ports
RS-232 x 2
Wired
RS-232
Data Transfer Rate
460 Kbps
Flow control
2 x RS-232 - 9 pin D-Sub (DB-9) (on cable)
Compatible Slots
1 x PCI Express Mini Card
2 x serial cable - 30 cm
WHQL, FCC, RoHS
Green
Limited warranty - lifetime
-20 °C
85 °C
5 - 85%
