StarTech.com 2 Port Powered USB Card
Quicklinx: 6LCWWS00 Mfr#: PCI1224PUSB
This PCI-based Powered USB Card adds two 12V and one 24V Powered USB ports to any computer, through an available PCI Slot.
Drawing power from either the PCI slot or the computer power supply, the Powered USB adapter card provides up to 3A of current to each connected device, allowing for up to three Powered USB devices to be installed at a time.
Plus, this Adapter Card can be connected to StarTech.com's 2 Port 12V/24V Powered USB Adapter Card (PUSBADAP), to create two additional Powered USB ports, without using an extra PCI slot. A Full-height bracket is attached to the adapter, and a low profile bracket is included in the packaging box for small form factor systems.
StarTech.com 2 Port 12V 1 Port 24V Dual Profile PCI Powered USB Card - USB adapter - PCI - 3 ports
USB adapter
Plug-in card - low profile
Interface (Bus) Type
PCI
PCI Specification Revision
PCI 2.2
Bus Voltage
Universal (3.3 V & 5.0 V)
14.5 cm x 6.5 cm x 2 cm
91 g
Ports Qty
3 ports
USB 2.0
Data Transfer Rate
480 Mbps
Microsoft Windows 98 Second Edition, Apple MacOS X, Microsoft Windows 2003, Microsoft Windows 2000 / ME / XP/ Vista
USB adapter - 3 ports
PCI
PCI 2.2
Bus Voltage
Wired
USB 2.0
Data Transfer Rate
480 Mbps
2 x PoweredUSB (12 V) - 8 pin USB PlusPower (12 V) (external) , 1 - 8 pin USB PlusPower (24 V) (external)
Compatible Slots
1 x PCI
FCC, RoHS
Software Included
Drivers & Utilities
14.5 cm
6.5 cm
2 cm
91 g
Limited warranty - lifetime
55 °C
0 - 95%
