Add 2 RS-232 serial ports to your PC with this dual voltage universal PCI expansion card. The PCI2S950DV 2 Port Dual Voltage PCI RS232 Serial Adapter Card w/ 16950 UART - lets you add 2 RS-232 serial ports using a PCI expansion slot offering high performance 16950 UART channels/ports for connecting any new or legacy serial peripherals, with data transfer rates of up to 460kbps.
A cost-effective solution for connecting serial modems, POS devices, printers, ISDN terminal adapters and more, the PCI serial card offers dual voltage support, allowing you to use a PCI (5V) or PCI-X (3.3V) slot for installation. The RS232 card also provides broad operating system support, IRQ sharing and a plug and play PCI interface with included standard and low profile slot brackets to guarantee convenient, hassle-free serial device connections on almost any system.
- StarTech.com 2 Port PCI RS232 Serial Adapter Card w/ 16950 UART - Dual Voltage - serial adapter - PCI-X - RS-232 x 2
- Serial adapter
- Form Factor
- Plug-in card - low profile
- Interface (Bus) Type
- PCI-X
- PCI Specification Revision
- PCI 2.2
- Bus Voltage
- Universal (3.3 V & 5.0 V)
- Ports
- RS-232 x 2
- Data Link Protocol
- RS-232
- Data Transfer Rate
- 460 Kbps
- System Requirements
- Microsoft Windows 95, Microsoft Windows 2000, Microsoft Windows 98 Second Edition / Windows ME, Linux Kernel 2.6.11 or later, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Windows 8 (32/64 bits)
- Limited lifetime warranty
- Designed For
- P/N: PEX2PCI4, PEX2PCIE4L
- Serial adapter
- Form Factor
- PCI-X
- PCI 2.2
- Bus Voltage
- Ports
- RS-232 x 2
- Connectivity Technology
- Wired
- RS-232
- 460 Kbps
- 2 x RS-232 - 9 pin D-Sub (DB-9)
- Compatible Slots
- 1 x PCI-X
- Included Accessories
- Low-profile bracket, full-height bracket
- FCC, RoHS
- Software Included
- Drivers & Utilities
- OS Required
- Limited warranty - lifetime
- Designed For
