StarTech.com 2-Port PCI RS232 Serial Adapter Card
Quicklinx: GGRKWS00 Mfr#: PCI2S5502
Wired / Wireless: Wired
Protocol: RS-232
Form Factor: Plug-in card
Compatibility: [N/A]
Type: Serial adapter
£20.00 ex VAT
£24.00 inc VAT
This multiport PCI RS232 serial adapter card lets you add two RS232 (DB9) serial ports to your computer through a PCI slot, as if they were native serial ports. The dual port PCI serial card enables you to interact with serial devices, such as card readers, printers, PIN pads, and modems, at speeds of up to 115.2Kbps.
With broad OS support, including for Windows (7 and up), and Linux (2.6.x to 5.x LTS versions only), this 2 port PCI serial card is easy to integrate into mixed environments. The card comes pre-configured with a full-profile bracket, and includes optional low-profile brackets, so installation is easy regardless of the case form factor. This card is a direct replacement for PCI2S550 LP and PCI2S550.
This PCI to serial adapter supports the following features: Industry standard 16C550 UART compatible; Supports baud rate up-to 115.2Kbps; 256-byte depth FIFO cache per transmitter and receiver; Supports 9, 8, 7, 6, 5 data bits (one per port); Asix MCS9865 chipset.
Low and full-profile brackets included.
  • Maximum Compatibility
    With broad OS support, including for Windows (7 and up), and Linux (2.6.x to 5.x LTS versions only), this 2 port PCI serial card is easy to integrate into mixed environments. The card comes pre-configured with a full-profile bracket, and includes optional low-profile brackets, so installation is easy regardless of the case form factor. This card is a direct replacement for PCI2S550_LP and PCI2S550.
  • Experience Optimal Technology
    This PCI to serial adapter supports the following features: • Industry standard 16C550 UART compatible • Supports baud rate up-to 115.2Kbps • 256-byte depth FIFO cache per transmitter and receiver • Supports 9, 8, 7, 6, 5 data bits (one per port) • Asix MCS9865 chipset • Low and full-profile brackets included PCI2S5502 is backed by a StarTech.com lifetime warranty with free 24/5 multi-lingual North American based technical support. StarTech.com has been the IT professionals' choice for over 30 years.
StarTech.com 2-Port PCI RS232 Serial Adapter Card, PCI Serial Port Expansion Controller Card, PCI to Dual Serial DB9 Card, Standard (Installed) & Low Profile Brackets, Windows/Linux - Dual Port PCI Serial Card (PCI2S5502) - serial adapter - PCI - RS-232 x 2
Serial adapter
Plug-in card - low profile
Interface (Bus) Type
PCI
Ports
RS-232 x 2
2.16 cm x 13.4 cm x 12 cm
141 g
Cabling Type
Serial RS-232
RS-232
Network / Transport Protocol
SPP
MCS9865
16C550 UART
Microsoft Windows 7 / 8 / 8.1 / 10, Linux 2.6.x to 5.x LTS versions, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Microsoft Windows Server 2019
Serial adapter
PCI
Ports
RS-232 x 2
Wired
Cabling Type
Serial RS-232
RS-232
SPP
256-byte FIFO
16C550 UART
Processor / Memory
MCS9865
2 x RS-232 - 9 pin D-Sub (DB-9)
2 x low-profile bracket
WHQL, RoHS, FCC, WEEE, RCM
2.16 cm
13.4 cm
12 cm
141 g
Shipping Width
14.2 cm
Shipping Depth
17 cm
Shipping Height
3 cm
Shipping Weight
170 g
Limited warranty - lifetime
70 °C
10 - 90% RH
GGRK StarTech.com DB9 RS232 Serial Null Modem Adapter - M/F In Stock £5.19
GGRK StarTech.com 1m Black DB9 Null Modem Cable In Stock £3.84
GGRK StarTech.com 2m Black DB9 Null Modem Cable In Stock £4.43
Protocol: RS-232
