StarTech.com 2m Black DB9 Null Modem Cable
Quicklinx: B14BWS00 Mfr#: SCNM9FF2MBK
Length: 2m
Select:
30 In Stock
£4.25 ex VAT
£5.10 inc VAT
Connect your serial devices, and transfer your files. The SCNM9FF2MBK 2m DB9 Null Modem Cable features two DB9 female connectors, allowing you to connect a serial device to a 9-pin serial port, or transfer files directly from PC to PC via a serial connection.
  • Durable construction
    The 2 m Black DB9 RS232 Serial Null Modem Cable features a robust design, ensuring long-lasting performance even in demanding environments.
  • Secure connection
    With molded connectors and thumbscrews, this cable provides a secure fit that prevents accidental disconnections during use.
  • EMI protection
    The cable is equipped with EMI protection, which helps to minimize signal interference, thereby enhancing overall data transmission quality.
  • Environmentally friendly
    Being RoHS compliant, this cable adheres to stringent environmental standards, making it a responsible choice for users.
StarTech.com 2m Black DB9 RS232 Serial Null Modem Cable F/F - DB9 Female to Female - 9 pin RS232 Null Modem Cable - 2 meter, Black - null modem cable - DB-9 to DB-9 - 2 m
Null modem cable
Molded, thumbscrews, EMI protection
Length
2 m
Connector
9 pin D-Sub (DB-9) - female
Connector (Second End)
P/N: PCI2S5502, PEX4S953, PEX4S953LP
Null modem cable
American Wire Gauge (AWG)
28
Plated Connector
Nickel
Length
2 m
Connector
RoHS
B14B StarTech.com 1m Black DB9 Null Modem Cable In Stock £3.88
B14B StarTech.com 2m Black DB9 Null Modem Cable In Stock £4.25
B14B StarTech.com RS232 Serial Null Modem Cable In Stock £7.00
Length: 2m
