This high performance EPP/ECP parallel card can be installed in a computer PCI slot, to add two IEEE 1284 ports to your PC. Supporting data transfer speeds of up to 1.5 Mbps (up to 3 times faster than built-in parallel ports), installing the EPP/ECP parallel adapter card is easy, with support for Windows Vista, XP, ME, 2000, 98, 95, NT4, DOS and Linux. Plus, IRQ sharing and plug and play capabilities guarantee convenient, hassle-free connections to any parallel peripheral.
A complete dual profile solution, this parallel adapter card provides both a standard bracket and a low profile bracket for adapting to slimline or small form factor system applications.
- StarTech.com 2 Port PCI Parallel Adapter Card - EPP/ECP - PCI DB25 Card - IEEE 1284 Card - PCI Parallel Card (PCI2PECP) - parallel adapter - PCI - IEEE 1284 x 2
- Parallel adapter
- Form Factor
- Plug-in card
- Interface (Bus) Type
- PCI
- Ports
- IEEE 1284 x 2
- Data Link Protocol
- Parallel
- Data Transfer Rate
- 2 Mbps
- System Requirements
- Microsoft DOS, Microsoft Windows 3.x/95/98, Microsoft Windows 2000 / NT4.0, Microsoft Windows Millennium Edition, Windows 10 (32/64 bits)
- Limited lifetime warranty
- Parallel adapter
- Form Factor
- Plug-in card
- PCI
- Ports
- IEEE 1284 x 2
- Connectivity Technology
- Wired
- Parallel
- 2 Mbps
- 2 x IEEE 1284 (EPP/ECP) - 25 pin D-Sub (DB-25) - female - 2
- Compatible Slots
- 1 x PCI
- Software Included
- Drivers & Utilities
- OS Required
- Limited warranty - parts and labour - lifetime
StarTech.com 2 Port PCI Parallel Adapter Card - EPP/ECP | In Stock | £39.07 |
