Add 2 external or internal SATA 6 Gbps ports to a computer, through a PCI Express slot. The PEXESAT322I PCI Express SATA III Controller Card (6 Gbps) gives you the option to add 2 internal or external SATA ports to your computer, through a single PCI Express (x1) card slot. The card features on board jumper selection, which enables you to configure the card to provide 2 internal or external SATA III ports, or one of each, as needed.
The SATA III card features Port Multiplier (PM) support on each port, which allows multiple drives to be connected over a single cable when necessary to maximize the number of SATA device connections while reducing the amount of cabling required.
The card is fully compliant with the SATA revision 3.0 specification (up to 6 Gbps of data bandwidth), enabling you to utilize the speeds of high performance hard drives and Solid State Drives (SSD), as well as SATA-based optical drives (CD-ROM, DVD-ROM, Blu-Ray).
- StarTech.com 2 Port PCI Express SATA 6 Gbps eSATA Controller Card - Dual Port PCIe SATA III Card - 2 Int/2 Ext - SATA III 6Gbps (PEXESAT322I) - storage controller - SATA 6Gb/s / eSATA 6Gb/s - PCIe x1
- Storage controller - plug-in card - low profile
- Bus Type
- PCIe x1
- Interface
- Data Transfer Rate
- 6 Gbit/s
- Channel Qty
- 2
- System Requirements
- Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits), Windows 10 (32/64 bits)
- 9.2 cm x 12.1 cm x 2 cm
- 48 g
- 2-year warranty
- Designed For
- P/N: S251SMU33EP, S3520BU33ER, S355BU33ERM, ST521PMINT
- Host Bus
- PCIe x1
Storage Controller
- Interface
- 6 Gbit/s
- Channel Qty
- 2
- 2 x eSATA 6Gb/s - eSATA (external) , 2 x SATA 6Gb/s - SATA (internal)
- Compatible Slots
- 1 x PCI Express x1
- Included Accessories
- Low-profile bracket
- Cables Included
- 1 x Serial ATA cable
- Native Command Queuing (NCQ)
- FCC, RoHS
- Software Included
- Drivers & Utilities
- OS Required
- Limited warranty - 2 years
- 9.2 cm
- 12.1 cm
- 2 cm
- 48 g
- 0 °C
- 50 °C
- 5 - 85%
- Designed For
StarTech.com 18" Serial ATA Cable w/R Angle | In Stock | £5.00 |
StarTech.com 18in Latching SATA Cable | In Stock | £5.24 |
StarTech.com 6 ft Shielded External eSATA Cable M/M | In Stock | £10.50 |
StarTech.com 18in SATA to Left Angle SATA Serial ATA Cable - F/F | In Stock | £6.02 |
StarTech.com 2 Port PCI Express SATA 6 Gbps eSATA Controller Card - 2 Int/2 Ext | In Stock | £30.82 |
