StarTech.com 2 Port PCI Express SATA 6 Gbps eSATA Controller Card - 2 Int/2 Ext
Quicklinx: 89Z0WS00 Mfr#: PEXESAT322I
  • Windows 8 (32/64 bits)
£27.49 ex VAT
£32.98 inc VAT
Add 2 external or internal SATA 6 Gbps ports to a computer, through a PCI Express slot. The PEXESAT322I PCI Express SATA III Controller Card (6 Gbps) gives you the option to add 2 internal or external SATA ports to your computer, through a single PCI Express (x1) card slot. The card features on board jumper selection, which enables you to configure the card to provide 2 internal or external SATA III ports, or one of each, as needed.
The SATA III card features Port Multiplier (PM) support on each port, which allows multiple drives to be connected over a single cable when necessary to maximize the number of SATA device connections while reducing the amount of cabling required.
The card is fully compliant with the SATA revision 3.0 specification (up to 6 Gbps of data bandwidth), enabling you to utilize the speeds of high performance hard drives and Solid State Drives (SSD), as well as SATA-based optical drives (CD-ROM, DVD-ROM, Blu-Ray).
StarTech.com 2 Port PCI Express SATA 6 Gbps eSATA Controller Card - Dual Port PCIe SATA III Card - 2 Int/2 Ext - SATA III 6Gbps (PEXESAT322I) - storage controller - SATA 6Gb/s / eSATA 6Gb/s - PCIe x1
Storage controller - plug-in card - low profile
Bus Type
PCIe x1
Data Transfer Rate
6 Gbit/s
Channel Qty
2
Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits), Windows 10 (32/64 bits)
9.2 cm x 12.1 cm x 2 cm
48 g
P/N: S251SMU33EP, S3520BU33ER, S355BU33ERM, ST521PMINT
Host Bus
PCIe x1
Storage Controller
Data Transfer Rate
6 Gbit/s
Channel Qty
2
2 x eSATA 6Gb/s - eSATA (external) , 2 x SATA 6Gb/s - SATA (internal)
Compatible Slots
1 x PCI Express x1
Low-profile bracket
1 x Serial ATA cable
Native Command Queuing (NCQ)
FCC, RoHS
Software Included
Drivers & Utilities
9.2 cm
12.1 cm
2 cm
48 g
50 °C
5 - 85%
