StarTech.com 2 Port PCI Express RS232 Serial Adapter Card with 16950 UART
Quicklinx: 5CBJWS00 Mfr#: PEX2S950
Add 2 RS232 serial ports to your standard or small form factor computer through a PCI Express expansion slot. The PEX2S950 2 Port PCI Express RS232 Serial Adapter Card with 16950 UART can be installed into an available PCI Express slot, to provide two high performance 16C950 RS232 serial UART channels/ports - a convenient solution for connecting modern or legacy serial devices with support for data transfer rates of up to 460 Kbps.
The 2 port RS232 serial card is easy to install and configure, with support for a broad range of Windows operating systems. Plus, the card features IRQ sharing and supports plug and play serial device connections, guaranteeing convenient, hassle-free installation.
StarTech.com 2 Port PCI Express RS232 Serial Adapter Card with 16550 UART - serial adapter - PCIe - RS-232 x 2
Serial adapter
Plug-in card
Interface (Bus) Type
PCI Express x1
Ports
RS-232 x 2
RS-232
Data Transfer Rate
460 Kbps
Microsoft Windows 95, Microsoft Windows 98, Microsoft Windows Millennium Edition, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Windows 10 (32/64 bits)
Serial adapter
Plug-in card
PCI Express x1
Ports
RS-232 x 2
Wired
RS-232
Data Transfer Rate
460 Kbps
Hardware flow control
2 x RS-232 - 9 pin D-Sub (DB-9)
Compatible Slots
1 x PCI Express x1
Plug and Play, WHQL, FCC, RoHS
Software Included
Drivers & Utilities
Limited warranty - lifetime
5CBJ StarTech.com DB9 to DB25 Serial Cable Adapter - F/M In Stock £5.28
