StarTech.com 2 Port PCI Express PCIe SuperSpeed USB 3.0 Controller Card w/ SATA Power
Quicklinx: 8XCCWS00 Mfr#: PEXUSB3S23
Type: USB adapter
Compatibility: PC
Interface: PCI Express x1
  • Windows 8 (32/64 bits)
33 in stock
£11.47 ex VAT
£13.76 inc VAT
Add two USB 3.0 ports to your desktop computer through a PCI Express slot. The PEXUSB3S23 2-Port PCI Express USB 3.0 Card lets you add two USB 3.0 ports to any PCI Express-enabled computer system. The USB card requires SATA power for functionality, and delivers 900mA of power per port to USB 3.0 bus-powered devices (500mA for USB 2.0) via your computers SATA power connector.
The PCIe USB 3.0 adapter is compliant with USB 3.0 standards for data transfer speeds up to 5 Gbps, while still offering backward compatibility with existing USB 2.0 / 1.1 devices. For added versatility, the controller card is equipped with a standard profile bracket and includes a low-profile/half-height bracket for installation in small form-factor computers.
StarTech.com 2 Port PCI Express USB 3.0 Controller Card w/ SATA Power - USB adapter - PCIe - USB 3.0 x 2 - PEXUSB3S23 - USB adapter - PCIe - USB 3.0 x 2
USB adapter
Plug-in card
Interface (Bus) Type
PCI Express x1
Ports
USB 3.0 x 2
2.1 cm x 8 cm x 12 cm
60 g
USB, USB 2.0, USB 3.0
Data Transfer Rate
5 Gbps
USB 1.1, USB 2.0, USB 3.0
Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits), Windows 10 (32/64 bits)
P/N: S3510SMU33, USB3S2ESATA3
USB adapter
Plug-in card
PCI Express x1
Ports
USB 3.0 x 2
Wired
USB, USB 2.0, SuperSpeed USB 3.0
Data Transfer Rate
5 Gbps
2 x USB 3.0 - 9 pin USB Type A (external)
Compatible Slots
1 x PCI Express x1
Low-profile bracket
FCC, RoHS
Software Included
Drivers & Utilities
2.1 cm
8 cm
12 cm
60 g
60 °C
10 - 90% (non-condensing)
8XCC StarTech.com USB 3.0 to SATA Hard Drive Docking Station for 2.5/3.5 HDD In Stock £37.11
8XCC StarTech.com 3 ft Black SuperSpeed USB 3.0 Cable A to B - M/M In Stock £4.83
8XCC StarTech.com 4 Port Black SuperSpeed USB 3.0 Hub In Stock £31.45
8XCC StarTech.com Mountable 4 Port Rugged Industrial SuperSpeed USB 3.0 Hub In Stock £89.45
8XCC StarTech.com 4 Port PCI Express PCIe SuperSpeed USB 3.0 Controller Card Adapter with UASP In Stock £34.35
8XCC StarTech.com 4 Port PCI SuperSpeed USB 3.0 Adapter Card with SATA / SP4 Power In Stock £52.96
8XCC StarTech.com 2 Port PCI Express PCIe SuperSpeed USB 3.0 Controller Card w/ SATA Power In Stock £11.47
Type: USB adapter
Compatibility: PC
Stock Status: In stock
