StarTech.com USB 3.0 to SATA Hard Drive Docking Station for 2.5/3.5 HDD
Quicklinx: 6PDNWS00 Mfr#: SATDOCKU3S
Type: HDD docking station
HD Size: 2.5, 3.5
Power Supply: Power adapter
15 In Stock
£41.40 ex VAT
£49.68 inc VAT
Enable fast, swappable access to your 2.5in or 3.5in SATA hard drives, through USB 3.0.
The SATDOCKU3S USB 3.0 Hard Drive Docking Station delivers full, instant access to any 2.5in or 3.5in SATA (SATA, SATA II, SATA III) hard drive (HDD) or solid state drive (SSD), without having to mount the drive in a computer or install it in an external enclosure. Large capacity drives (tested with up to 4TB) can be used to greatly enhance your computer's storage/backup capabilities.
Connected to the host computer through a single USB 3.0 SuperSpeed or USB 2.0 connection, the hard drive docking station provides a convenient, plug-and-play storage solution that delivers instant access to the hard drive without requiring a reboot.
Relying on the outstanding data throughput support of USB 3.0, the HDD docking station is capable of transfer speed up 5Gbps, making it the fastest way to access data from an external drive. Double the value of this hard drive docking station, using a SATA to IDE hard drive adapter (SAT2IDEADP), which enables you to use any 2.5 or 3.5in IDE hard drive in a SATA hard drive dock slot.
  • Versatile hard drive compatibility
    Compatible with both 2.5" and 3.5" hard drives, facilitating diverse storage solutions for various applications.
  • Fast data transfer rates
    Utilizes USB 3.0 technology to achieve data transfer speeds of up to 3 Gbit/s, ensuring quick access to your files.
  • Hot-swap functionality
    Allows for easy swapping of hard drives without shutting down the system, enhancing workflow and productivity.
  • Robust environmental design
    Operates well in a temperature range of 5°C to 80°C and functions efficiently in varying humidity conditions.
  • Plug-and-Play setup
    Supports easy installation with no additional software required, providing instant access to external hard drives.
StarTech.com SuperSpeed USB 3.0 to SATA Hard Drive Docking station for 2.5/3.5 HDD - HDD Docking station - SATA Dock - HDD docking station - SATA 3Gb/s - USB 3.0
HDD docking station - external
Bays
1
Bus Type
USB 3.0
Expansion Bays
1 x hot-swap - 2.5" / 3.5" shared
Hard Drive Form Factor Compatibility
2.5", 3.5"
SATA 3Gb/s
Data Transfer Rate
3 Gbit/s
Supported Devices
Hard drive
Power Source
Included AC adapter
AC 120/230 V
Microsoft Windows Server 2003, Apple MacOS X or later, Microsoft Windows 7, Microsoft Windows Vista / 2000 / XP, Microsoft Windows Server 2008
9.3 cm x 14.5 cm x 6.5 cm
410 g
P/N: PEXUSB3S23, PEXUSB3S24, PEXUSB3S25, PEXUSB3S42V, PEXUSB3S44V, PEXUSB3S4V, SAT2IDEADP, SVA12M2NEUA, SVA12M5NA, USB3SAB1, USBDUP15, USBDUPE115, USBDUPE17
Bays
1
2.5", 3.5"
Host Bus
USB 3.0
Storage Controller
SATA 3Gb/s
Data Transfer Rate
3 Gbit/s
Supported Devices
Hard drive
Bays
1 x SATA 3Gb/s - SATA power , 1 x SATA 3Gb/s - SATA
1 x USB 3.0 - 9 pin USB Type B
1 x USB cable - external , 1 x Serial ATA cable - external
Tested with up to 4TB 5400 RPM 3.5” hard drives, tested with up to 1TB 5400 RPM 2.5” hard drives
Plug and Play, FCC, RoHS
Power Source
Included AC adapter
Power adapter
AC 120/230 V
9.3 cm
14.5 cm
6.5 cm
410 g
5 °C
80 °C
8 - 80%
6PDN StarTech.com 2.5in Silicone Laptop Hard Drive Protector Sleeve with Connector Cap In Stock £3.33
6PDN StarTech.com USB 3.0 to SATA Hard Drive Docking Station for 2.5/3.5 HDD In Stock £41.40
6PDN StarTech.com SATA to 2.5in or 3.5in IDE Hard Drive Adapter for HDD Docks In Stock £19.65
6PDN StarTech.com 2.5in Anti-Static Hard Drive Protector Case - Black (3 Pack) In Stock £12.36
6PDN StarTech.com USB 3.0 SATA III Hard Drive Docking Station SSD / HDD with UASP In Stock £38.06
6PDN StarTech.com USB 3.0 / eSATA Dual Hard Drive Docking Station with UASP for 2.5/3.5in SATA SSD / HDD In Stock £63.79
6PDN StarTech.com USB 3.1 Gen 2 Dual-bay Dock In Stock £82.78
6PDN StarTech.com USB 3.1 / eSATA 1-bay Dock In Stock £54.05
6PDN StarTech.com DC Power Adapter - 12V, 2A In Stock £11.76
6PDN StarTech.com DC Power Adapter - 12V, 5A In Stock £42.05
6PDN StarTech.com Dual-Bay SATA HDD/SSD Dock In Stock £51.66
HD Size: 2.5
HD Size: 3.5
