Add two USB 3.0 ports to your desktop computer through a PCI Express slot. The PEXUSB3S23 2-Port PCI Express USB 3.0 Card lets you add two USB 3.0 ports to any PCI Express-enabled computer system. The USB card requires SATA power for functionality, and delivers 900mA of power per port to USB 3.0 bus-powered devices (500mA for USB 2.0) via your computers SATA power connector.
The PCIe USB 3.0 adapter is compliant with USB 3.0 standards for data transfer speeds up to 5 Gbps, while still offering backward compatibility with existing USB 2.0 / 1.1 devices. For added versatility, the controller card is equipped with a standard profile bracket and includes a low-profile/half-height bracket for installation in small form-factor computers.
- StarTech.com 2 Port PCI Express USB 3.0 Controller Card w/ SATA Power - USB adapter - PCIe - USB 3.0 x 2 - PEXUSB3S23 - USB adapter - PCIe - USB 3.0 x 2
- USB adapter
- Form Factor
- Plug-in card
- Interface (Bus) Type
- PCI Express x1
- Ports
- USB 3.0 x 2
- 2.1 cm x 8 cm x 12 cm
- 60 g
- Data Link Protocol
- USB, USB 2.0, USB 3.0
- Data Transfer Rate
- 5 Gbps
- USB 1.1, USB 2.0, USB 3.0
- System Requirements
- Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits), Windows 10 (32/64 bits)
- 2-year warranty
- Designed For
- P/N: S3510SMU33, USB3S2ESATA3
- USB adapter
- Form Factor
- Plug-in card
- PCI Express x1
- Ports
- USB 3.0 x 2
- Connectivity Technology
- Wired
- USB, USB 2.0, SuperSpeed USB 3.0
- 5 Gbps
- 2 x USB 3.0 - 9 pin USB Type A (external)
- Compatible Slots
- 1 x PCI Express x1
- Included Accessories
- Low-profile bracket
- FCC, RoHS
- Software Included
- Drivers & Utilities
- OS Required
- 2.1 cm
- 8 cm
- 12 cm
- 60 g
- Limited warranty - 2 years
- 0 °C
- 60 °C
- 10 - 90% (non-condensing)
- Designed For
StarTech.com USB 3.0 to SATA Hard Drive Docking Station for 2.5/3.5 HDD | In Stock | £40.39 |
StarTech.com 4 Port Black SuperSpeed USB 3.0 Hub | In Stock | £36.67 |
StarTech.com Mountable 4 Port Rugged Industrial SuperSpeed USB 3.0 Hub | In Stock | £98.93 |
StarTech.com 4 Port PCI Express PCIe SuperSpeed USB 3.0 Controller Card Adapter with UASP | In Stock | £36.02 |
StarTech.com 2 Port PCI Express PCIe SuperSpeed USB 3.0 Controller Card w/ SATA Power | In Stock | £11.59 |
StarTech.com 7 Port PCIe USB 3.0 Card | In Stock | £58.33 |
StarTech.com 4 Port PCIe USB 3.0 Card | In Stock | £28.40 |
