Extend a USB 3.0 Motherboard Header into Two Panel-mount USB 3.0-A Ports. The USB3SPNLAFHD 2-Port USB 3.0 to Panel mount USB cable features a 20-pin USB 3.0 motherboard header connection on one end, breaking off into two separate USB 3.0-A (female) ports on the other end of the cable.
The USB 3.0 panel mount cable offers a convenient solution for connecting bootable thumb drives or authentication fobs etc. to the motherboard USB 3.0 connection.
- StarTech.com 2 Port Panel Mount USB 3.0 Cable - USB A to Motherboard Header Cable F/F (USB3SPNLAFHD) - USB internal to external cable - USB Type A to 20 pin IDC - 50 cm
- Technology
- Shielded
- Length
- 50 cm
- Connector
- 2 x 9 pin USB Type A - female
- Connector (Second End)
- 20 pin IDC - female
- USB 3.0
- Blue
- Limited lifetime warranty
- Technology
- Shielded
- American Wire Gauge (AWG)
- 28
- Length
- 50 cm
- Blue
- Connector
- USB 3.0, RoHS
