StarTech.com 2 Port Native PCI Express RS232 Serial Adapter Card with 16550 UART
Quicklinx: 76T3WS00 Mfr#: PEX2S553
Type: Serial adapter
Compatibility: PC
Interface: PCI Express
15 In Stock
£35.75 ex VAT
£42.90 inc VAT
The PEX2S553 PCI Express serial card lets you turn a PCI Express slot into 2 RS232 (DB9) serial ports. Based on a native single chip design (no bridge chip), this 2-port serial adapter card allows you to harness the full capability offered by PCI Express (PCIe), and reducing the load applied to the CPU by as much as 48% over conventional serial cards.
The RS232 Serial adapter card (PEX2S553) is compatible with a broad range of operating systems including Windows 2000/XP/2003/Vista/Windows 7/Server 2008 R2 (32 and 64 bit), Linux Kernel 2.6.11 and up, and MAC OS 10.4 and above. Plus, the serial card includes an optional half-height/low profile bracket that allows the card to be installed in any PCI Express slot, regardless of the size of the computer case. This product is a replacement for the PEX2S552 card.
StarTech.com 2 Port Native PCI Express RS232 Serial Adapter Card with 16550 UART (PEX2S553) - serial adapter - PCIe - RS-232 x 2
Serial adapter
Plug-in card - low profile
Interface (Bus) Type
PCI Express
Ports
RS-232 x 2
12 cm x 10.5 cm x 2 cm
61 g
RS-232
Microsoft DOS, Microsoft Windows 2000, Microsoft Windows 95/98 Second Edition, Microsoft Windows XP, Microsoft Windows XP Embedded, Microsoft Windows Server 2003, Microsoft Windows Embedded Standard 2009, Microsoft Windows CE 5.0, Microsoft Windows Embedded POSReady 2009, Microsoft Windows Server 2008 R2, Microsoft Windows CE 6.0, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Apple MacOS X 10.4 - 10.10, Microsoft Windows Vista / 7 / 8 / 8.1 / 10, Microsoft Windows Server 2016, Linux 2.6.x to 4.11.x LTS versions, Microsoft Windows Server 2019
P/N: BNDTB10GI, BNDTB1394B3, BNDTB210GSFP, BNDTB310GNDP, BNDTB410GSFP, BNDTB4M2E1, BNDTBUSB3142, TB31PCIEX16
Serial adapter
PCI Express
Ports
RS-232 x 2
Wired
RS-232
2 x RS-232 - 9 pin D-Sub (DB-9)
Compatible Slots
1 x PCI Express
WHQL, FCC
12 cm
10.5 cm
2 cm
61 g
-20 °C
85 °C
5 - 85%
76T3 StarTech.com 1 Port Low Profile Native RS232 PCI Express Serial Card with 16550 UART In Stock £37.06
76T3 StarTech.com 2 Port Native PCI Express RS232 Serial Adapter Card with 16550 UART In Stock £35.75
76T3 StarTech.com 2S1P Native PCI Express Parallel Serial Combo Card with 16550 UART In Stock £29.12
76T3 StarTech.com 2 Port Low Profile Native RS232 PCI Express Serial Card with 16550 UART In Stock £34.33
76T3 StarTech.com 4 Port RS232 PCI Express Serial Card w/ Breakout Cable In Stock £89.06
76T3 StarTech.com 4 Port Native PCI Express RS232 Serial Adapter Card with 16550 UART In Stock £81.96
76T3 StarTech.com DB9 to DB25 Serial Cable Adapter - F/M In Stock £5.28
76T3 StarTech.com 2 Port PCI Express RS232 Serial Adapter Card In Stock £42.19
76T3 StarTech.com 8-Port PCI Express RS232 Serial Adapter Card - PCIe - 15kV ESD In Stock £178.87
76T3 StarTech.com PCIe Dual Serial Port Card In Stock £48.46
Compatibility: PC
