StarTech.com 2 Port Native ExpressCard RS232 Serial Adapter Card with 16950 UART
Quicklinx: 6BD2WS00 Mfr#: EC2S952
Type: Serial adapter
Compatibility: PC
Interface: ExpressCard/34
£43.58 ex VAT
£52.29 inc VAT
Add 2 high-speed RS-232 Serial ports to your notebook computer via an ExpressCard slot. This 2 Port ExpressCard-based Serial Card lets you add 2 RS232 serial ports to your laptop or ExpressCard equipped desktop computer, using an available ExpressCard slot.
Featuring 128-byte FIFO communication, and a high performance 16C950 UART, the ExpressCard Serial Adapter card offers baud rates up to 115.2Kbps, which ensures peak communication with your serial peripheral devices.
The serial card is designed based on a single-chip architecture (as opposed to cards that use a "bridge chip"), providing native PCI Express communication for greater performance and reliability, as well as reduced power consumption and CPU load.
Compatible with ExpressCard /34mm and ExpressCard 54mm card slots, the 2 Port Serial ExpressCard includes a slot spacer for greater security while installed in 54mm slots.
StarTech.com 2 Port Native ExpressCard RS232 Serial Adapter Card with 16952 UART - serial adapter
Serial adapter
Plug-in module
Interface (Bus) Type
ExpressCard/34
Ports
RS-232 x 2
4.5 cm x 11.5 cm x 2 cm
34 g
RS-232
Data Transfer Rate
460 Kbps
Microsoft Windows 95/98/ME/XP, Microsoft Windows Vista
Serial adapter
Plug-in module
ExpressCard/34
Ports
RS-232 x 2
Wired
RS-232
Data Transfer Rate
460 Kbps
2 x RS-232 - 9 pin D-Sub (DB-9)
Compatible Slots
1 x ExpressCard/34 , 1 x ExpressCard/54
FCC, RoHS
4.5 cm
11.5 cm
2 cm
34 g
Limited warranty - lifetime
6BD2 StarTech.com 10 ft DB9 RS232 Serial Null Modem Cable F/M In Stock £3.83
6BD2 StarTech.com 10 ft DB9 RS232 Serial Null Modem Cable F/F In Stock £4.29
6BD2 StarTech.com 10 ft Cross Wired DB9 to DB25 Serial Null Modem Cable - F/M In Stock £3.93
6BD2 StarTech.com 1 Port PCI Express Dual Profile Parallel Adapter Card - SPP/EPP/ECP In Stock £18.76
6BD2 StarTech.com 1 Port Native ExpressCard RS232 Serial Adapter Card with 16950 UART In Stock £38.01
6BD2 StarTech.com DB9 RS232 Serial Null Modem Adapter - M/F In Stock £4.32
Compatibility: PC
Price Range Ex VAT: 0 - 50
