This Null Modem Adapter features two DB9 female connectors - a cost-saving way to convert a straight through cable into a null modem cable.
Reliable connection
Featuring dual 9-pin D-Sub (DB-9) female connectors, this adapter provides a consistent connection for serial communication between devices. -
User-friendly design
The straightforward Plug-and-Play design eliminates the need for complex setup, making it easy to connect and communicate between serial devices.
- StarTech.com DB9 RS232 Serial Null Modem Adapter - F/F - Null modem adapter - DB-9 (F) to DB-9 (F) - NM9FF - null modem adapter - DB-9 to DB-9
- Connector
- 9 pin D-Sub (DB-9) - female
- Connector (Second End)
- Limited lifetime warranty
- Designed For
- P/N: EC1S952, EC2S952, PCI2S232485I
- Connector
- Designed For
