StarTech.com 2 Port Mini PCI Express Internal SATA II Controller Card
Quicklinx: 7NZRWS00 Mfr#: MPEXSATA22I
The MPEXSATA22I 2-Port Mini PCIe to SATA Controller Card lets you add 2 SATA 3Gbps connectors to a small form factor or embedded system, through a Mini PCI Express (Mini Card) expansion slot.
Perfect for upgrading the capabilities of a system that would typically have a very limited number of internal ports, the Mini PCIe to SATA controller card is compatible with all types of Serial ATA devices, including hard drives (HDDs), Solid State Drives (SSD), and optical drives (CD/DVD/BD).
A versatile solution for internal storage applications, this PCI Express to SATA controller card features built-in RAID support (JBOD, BIG, RAID 0, RAID 1).
StarTech.com 2 Port Mini PCI Express Internal SATA II Controller Card - storage controller - SATA 3Gb/s / eSATA 3Gb/s - PCIe Mini Card
Storage controller - plug-in module
Bus Type
PCIe Mini Card
Data Transfer Rate
3 Gbit/s
Supported Devices
Hard drive
Channel Qty
2
Max Storage Devices Qty
2
RAID Level
RAID 0, RAID 1, JBOD, BIG
Microsoft Windows 2000 / XP, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Apple MacOS X 10.4.9, Apple MacOS X 10.4.10, Apple MacOS X 10.5.1
5 cm x 3 cm x 0.4 cm
7.8 g
Host Bus
PCIe Mini Card
Storage Controller
Data Transfer Rate
3 Gbit/s
Supported Devices
Hard drive
Channel Qty
2
2
RAID Level
Silicon Image SiI3132
2 x SATA 3Gb/s / eSATA 3Gb/s - eSATA (external)
Compatible Slots
1 x PCI Express Mini Card
FCC, RoHS
5 cm
3 cm
0.4 cm
7.8 g
70 °C
7NZR StarTech.com 24" Serial ATA Cable In Stock £5.16
7NZR StarTech.com 18" Serial ATA Cable w/R Angle In Stock £5.00
7NZR StarTech.com 18in SATA Serial ATA Cable In Stock £2.51
7NZR StarTech.com 36in SATA Serial ATA Cable In Stock £5.68
7NZR StarTech.com 12in Latching SATA Cable In Stock £5.48
7NZR StarTech.com 12in Latching SATA to Right Angle SATA Serial ATA Cable In Stock £4.84
7NZR StarTech.com 6in SATA Serial ATA Cable In Stock £3.55
7NZR StarTech.com 12in SATA Serial ATA Cable In Stock £4.44
7NZR StarTech.com 18in SATA to Left Angle SATA Serial ATA Cable - F/F In Stock £6.14
