This high quality SATA cable is designed for connecting SATA drives even in tight spaces. The SATA12 Serial ATA Cable features two 7-pin data receptacles and supports full SATA 3.0 bandwidth of up to 6Gbps when used with SATA 3.0 compliant drives.
Featuring a low profile, yet durable construction, the flexible design improves airflow and reduces clutter in your computer case, helping to keep the case clean and cool.
- StarTech.com 12in SATA Serial ATA Cable - SATA cable - Serial ATA 150/300 - SATA (F) to SATA (F) - 1 ft - red - SATA12 - SATA cable - 30.5 cm
- SATA cable
- Interface Speed
- Length
- 30.5 cm
- Connector
- 7 pin Serial ATA - female
- Connector (Second End)
- Red
- Limited lifetime warranty
- Designed For
- P/N: 10P6G-PCIE-SATA-CARD, 25S22M2NGFFR, 25SAT22MSAT, 25SATSAS35, 25SATSAS35HD, 2P6G-PCIE-SATA-CARD, 4P6G-PCIE-SATA-CARD, 6P6G-PCIE-SATA-CARD, MSAT2SAT3, S322M225R, S32M2NGFFPEX, SAT2M2NGFF25, SAT2MSAT25, SAT32M225, SAT32MSAT257, SAT32MSATM, SAT32MSATPEX, SATBP125VP, USB2SATAIDE, USB3SSATAIDE
- Storage Cable Type
- SATA cable
- Interface Speed
- Shielding Material
- PVC
- American Wire Gauge (AWG)
- 26
- Length
- 30.5 cm
- Red
- Connector
- RoHS
- Designed For
StarTech.com 18" Serial ATA Cable w/R Angle | In Stock | £5.00 |
StarTech.com 12in Latching SATA Cable | In Stock | £5.50 |
StarTech.com 18in Latching SATA Cable | In Stock | £3.98 |
StarTech.com 12in SATA Serial ATA Cable | In Stock | £4.46 |
