StarTech.com 2-port KVM Console Adapter
Quicklinx: C195WS00 Mfr#: SV231USBLC
£277.60 ex VAT
£333.12 inc VAT
This 2-port USB crash-cart adapter gives you KVM control of your servers, directly from your laptop. It's a convenient solution for routine diagnostics, maintenance and updates for small-scale server applications, giving you full console access to servers located in small spaces, or congested server racks. It's also perfect for environments where a fixed-installation console server isn't feasible, such as in a server closet or wall-mounted server rack.
The USB crash-cart adapter offers a cost-effective and convenient way to access and control your servers. At a fraction of the cost of a rack-mounted LCD console, installing this easy-to-use adapter means not having to wheel around a conventional server-room crash cart.
Instead of the expense of a dedicated rack console, or hassle of a full-scale crash cart, you can multi-purpose your laptop and save your IT budget by using equipment you already have on hand.
Using the included software, the adapter can do things that regular KVMs can't. The software provides a robust and flexible interface that lets you view your servers on your full laptop screen, without scroll bars, and lets you reduce the viewing window so that you can work on your laptop and servers at the same time to maximize your productivity.
The software also supports file transfers between your laptop and the servers, which is perfect for server software updates and patches. The adapter's software also offers video capture support, so you can record your activity on the servers as video, which you can later use for verification or instructional purposes.
The USB crash cart is easy to install, using the included mounting brackets and 2-in-1 USB and VGA cables. Installing the included software on your laptop is also easy, using the included pre-loaded USB key.
  • Maximize your IT budget, minimize your hassle
    The USB crash-cart adapter offers a cost-effective and convenient way to access and control your servers. At a fraction of the cost of a rack-mounted LCD console, installing this easy-to-use adapter means not having to wheel around a conventional server-room crash cart. Instead of the expense of a dedicated rack console, or hassle of a full-scale crash cart, you can multi-purpose your laptop and save your IT budget by using equipment you already have on hand.
  • Streamline your server maintenance
    Using the included software, the adapter can do things that regular KVMs can't. The software provides a robust and flexible interface that lets you view your servers on your full laptop screen, without scroll bars, and lets you reduce the viewing window so that you can work on your laptop and servers at the same time to maximize your productivity. The software also supports file transfers between your laptop and the servers, which is perfect for server software updates and patches. The adapter's software also offers video capture support, so you can record your activity on the servers as video, which you can later use for verification or instructional purposes.
  • Get up and running in minutes
    The USB crash cart is easy to install, using the included mounting brackets and 2-in-1 USB and VGA cables. Installing the included software on your laptop is also easy, using the included pre-loaded USB key. The SV231USBLC is backed by a 2-year StarTech.com warranty, and free lifetime technical support.
StarTech.com 2-port KVM Console Adapter - Rackmount Crash Cart Adapter - KVM switch - 2 ports
Subtype
KVM
Ports
2 x KVM port(s)
KVM Users Qty
1 local user
AC 120/230 V
244 g
Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Linux 2.6.x to 4.11.x LTS versions, Microsoft Windows Server 2019, Apple MacOS X 10.6 - 10.15, Apple macOS 11.0, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0, Apple macOS 13.0
P/N: SVA5N3NEUA
Enclosure Type
Desktop
Subtype
KVM
Ports
2 x KVM port(s)
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
USB
Max Resolution
1920 x 1200 @ 60 Hz
Status Indicators
Port status, console, KVM
1 x VGA output HD-15 , 2 x VGA input HD-15 , 2 x USB 2.0 Type B , 4 x USB 2.0 Type A , 1 x USB 2.0 Type A charging port , 1 x console (mini-USB)
External power adapter
AC 120/230 V
2 mounting brackets
2 x VGA / USB cable - 3.05 m , 1 x mini-USB to USB cable
UL, FCC, RoHS
244 g
P/N: SVA5N3NEUA
C195 StarTech.com 6 ft 2-in-1 USB KVM Cable In Stock £7.06
C195 StarTech.com 10 ft 2-in-1 Universal USB KVM Cable In Stock £11.01
C195 StarTech.com KVM Console to USB 2.0 Portable Laptop Crash Cart Adapter In Stock £368.24
C195 StarTech.com 15 ft 2-in-1 Universal USB KVM Cable In Stock £15.07
C195 StarTech.com KVM Console to Laptop USB 2.0 Portable Crash Cart Adapter with File Transfer In Stock £381.45
C195 StarTech.com Laptop to Server KVM Console In Stock £433.25
C195 StarTech.com DC Power Adapter - 5V, 3A In Stock £12.25
