The NOTECONS02 Portable USB Crash Cart Adapter lets you turn your laptop into a portable console for rack servers, PCs, ATMs, kiosks and more, now with local file transfer built-in. Simply connect the crash cart adapter to your laptop using the included USB cable, then connect the integrated USB and VGA cables to your server for instant, BIOS-level control.
Get connected in seconds. The crash cart adapter offers integrated VGA and USB cables for the server-side connections and includes the USB cable to connect to your laptop.
Troubleshoot your devices faster with a flexible software interface that lets you transfer files from your laptop to the server, take screenshots and scale the display window to full screen mode or smaller, with no scroll bars - ever.
With no server-side software installation required, the USB crash cart adapter can connect to any PC or device that has a VGA and USB port, to provide BIOS-level control.
Powered from the server-side USB connection, the laptop crash cart adapter doesn't require an AC outlet and saves your laptop / netbook battery power.
With portability for the mobile administrator or repair technician in mind, this pocket-sized adapter features a rugged design that easily fits inside your laptop bag and requires no additional accessories to connect.
Eliminating the need to lug around a large, awkward traditional crash cart to troubleshoot and service your systems, this portable crash cart lets you connect to a headless device with only a laptop.
Instant System Access
Simply connect the laptop crash cart adapter to your computer using the included USB cable, then connect the integrated USB and VGA cables to your server for instant BIOS-level control. With no server-side software required, you can be up and running instantly. -
Troubleshoot More Efficiently
With the flexible software interface, you can transfer files from your laptop to the server, capture videos for records or instructional purposes, take screenshots and scale the display window to full screen mode or smaller, with no scroll bars helping you to troubleshoot faster. -
Self-Powered Reliability
Powered from the server-side USB connection, the KVM adapter doesn't require an AC outlet so you can connect to any PC or device that has a VGA and USB port, even if there's no power outlet available. -
Take It Anywhere
This pocket-sized adapter features a compact design that easily fits inside your laptop bag and requires no additional accessories to connect, eliminating the need to lug around a large, awkward traditional crash cart to troubleshoot and service your systems. StarTech.com offers a wide selection of high-quality KVM-related products to help you access your systems more efficiently without the expense and clutter of extra keyboards, mice and monitors. This USB KVM crash cart adapter is backed by a StarTech.com 2-year warranty and free lifetime technical support.
- StarTech.com USB Crash Cart Adapter - File Transfer & Video - Portable Server Room Laptop to KVM Console Crash Cart (NOTECONS02) - KVM switch - 1 ports
- Subtype
- KVM
- Ports
- 1 x KVM port(s)
- KVM Users Qty
- 1 local user
- Firmware upgradable
- 7.4 cm x 11.5 cm x 1.5 cm
- 170 g
- Black
- System Requirements
- Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10 / 11, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Microsoft Windows Server 2019, Apple MacOS X 10.9 - 10.15, Apple macOS 11.0, Apple macOS 12.0, Apple macOS 13.0, Linux 2.6 or later, Linux LTS versions only
- 2-year warranty
- Enclosure Type
- Desktop
- Subtype
- KVM
- Ports
- 1 x KVM port(s)
- KVM Local Users Qty
- 1 local user
- Keyboard / Mouse Interface
- USB
- Max Resolution
- 1920 x 1200 @ 60 Hz
- Status Indicators
- Link/activity
- 2 x USB 2.0 Type A , 1 x VGA HD-15
- Black
- Cables Included
- 1 x USB host cable - 38.5 cm , 1 x USB cable - 1.8 m , 1 x VGA cable - 7.6 cm
- FCC, RoHS
- OS Required
- 7.4 cm
- 11.5 cm
- 1.5 cm
- 170 g
- Limited warranty - 2 years
- 0 °C
- 40 °C
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
StarTech.com DVI to VGA Cable Adapter - M/F | In Stock | £5.47 |
StarTech.com KVM Console to USB 2.0 Portable Laptop Crash Cart Adapter | In Stock | £382.86 |
StarTech.com HDMI to VGA Adapter Converter for Desktop PC / Laptop / Ultrabook - 1920x1080 | In Stock | £26.54 |
StarTech.com KVM Console to Laptop USB 2.0 Portable Crash Cart Adapter with File Transfer | In Stock | £421.27 |
StarTech.com Laptop to Server KVM Console | In Stock | £475.18 |
StarTech.com 17.3" Laptop Backpack w/ Case | In Stock | £105.31 |
