StarTech.com 2 Port Internal USB 3.0 Motherboard Header Adapter Cable
Quicklinx: 8JFSWS00 Mfr#: USB3SMBADAP6
Length: 15.24cm
10 in stock
£12.54 ex VAT
£15.04 inc VAT
Connect 2 internal USB 3.0 devices (internal card reader, hard drive) directly to a motherboard header connection. The USB3SMBADAP6 Internal USB 3.0 Adapter Cable extends a 20-pin motherboard USB 3.0 header connection and enables you to add 2 internal female USB 3.0 (Type A) ports.
With the addition of the 2 internal USB 3.0 ports, you can connect your internal devices (internal card reader, hard drive, etc.) directly to your motherboard, which allows for a cleaner installation, avoiding the need to run your cables outside the system case to external USB 3.0 ports.
This USB 20-pin Adapter offers 6-inches in cable length, which lessens strain on the motherboard header, ensuring a reliable, long-lasting connection.
StarTech.com 2 Port Internal USB 3.0 Motherboard Header Adapter Cable - USB internal adapter - 15.24 cm
Shielded
Length
15.24 cm
Connector
2 x 9 pin USB Type A - female
Connector (Second End)
20 pin USB 3.0 header - female
USB / USB 2.0 / USB 3.0
Shielded
American Wire Gauge (AWG)
28
Plated Connector
Nickel
Length
15.24 cm
Connector
USB / USB 2.0 / USB 3.0, RoHS
8JFS StarTech.com 2 Port USB Motherboard Header Adapter In Stock £9.30
8JFS StarTech.com 2 Port USB 3.0 A Female Slot Plate Adapter In Stock £14.30
8JFS StarTech.com 2 Port Panel Mount USB 3.0 Cable - USB A to Motherboard Header Cable F/F In Stock £11.10
Length: 15.24cm
Price Range Ex VAT: 0 - 50
