Split an HDMI audio and video signal to two displays simultaneously.
The ST122HDMI2 2-Port High Speed HDMI Splitter and Signal Amplifier lets you share a single HDMI source signal with audio between two HDMI or DVI (using HDMI to DVI adapter) enabled displays simultaneously.
Supporting True HD 1080p video resolutions, the HDMI splitter acts as a distribution amplifier that enables you to situate your HDMI-capable displays up to 50ft (15m) away from the splitter, and features 3.5mm audio connections, giving you the option of sending your accompanying audio signal through the HDMI cable, or through a separate channel.
The HDMI splitter is easy to install and use with no software or configuration required, for a completely plug-and-play setup that can be used with HDMI output devices such as Blu-ray players or desktop/laptop computers.
- StarTech.com HDMI Splitter 1 In 2 Out - 1080p - 2 Port - Signal Amplifier - Rugged - HDMI Multi Port - HDMI Audio Splitter (ST122HDMI2) - video/audio splitter - 2 ports
- Video/audio splitter - 2 ports
- Subtype
- HDMI
- Ports
- 2 x HDMI
- HDCP compliant
- Power
- AC 120/230 V
- 8 cm x 18 cm x 1.9 cm
- 0.5 kg
- Black
- 3-year warranty
- Designed For
- P/N: SVA12M2NEUA, SVA12M5NA
- Enclosure Type
- Desktop
- Subtype
- HDMI
- Ports
- 2 x HDMI
- Max Resolution
- 1080p
- HDCP compliant
- 2 x HDMI output , 1 x HDMI input , 1 x audio input mini-jack , 2 x audio output mini-jack
- Power Device
- External power adapter
- Voltage Required
- AC 120/230 V
- Black
- FCC, RoHS
- 8 cm
- 18 cm
- 1.9 cm
- 0.5 kg
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 0 - 80%
- Designed For
StarTech.com 6 ft HDMI to DVI-D Cable - M/M | In Stock | £9.62 |
StarTech.com HDMI to DVI-D Video Cable Adapter - M/F | In Stock | £8.98 |
StarTech.com 2 Port DVI Video Splitter with Audio | In Stock | £91.86 |
StarTech.com 10 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £4.99 |
StarTech.com 15 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £5.83 |
StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £3.79 |
StarTech.com 4 Port High Speed HDMI Video Splitter w/ Audio | In Stock | £95.61 |
StarTech.com 2 Port High Speed HDMI Video Splitter and Signal Amplifier | In Stock | £71.73 |
StarTech.com 3 ft Stereo Audio Cable - 3.5mm Male to 2x RCA Male | In Stock | £5.05 |
StarTech.com 4K HDMI 2-Port Video Splitter – 1x2 HDMI Splitter – Powered by USB or Power Adapter | In Stock | £53.82 |
StarTech.com 4K HDMI 4-Port Video Splitter | In Stock | £62.00 |
StarTech.com 8-Port 4K 60Hz HDMI Splitter | In Stock | £134.31 |
StarTech.com HDMI Splitter - 4 Port - 4K 60Hz | In Stock | £54.49 |
